How much does a Kubota M7040 cab weigh? Just the cab.
   / How much does a Kubota M7040 cab weigh? Just the cab. #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
How much does a Kubota M7040 cab weigh? I mean, over the same model without a cab?
I have to haul one and know what one weighs without a cab but not how much one weighs with a cab.
   / How much does a Kubota M7040 cab weigh? Just the cab. #2
Weight:4,675 lbs [2120 kg] (2WD ROPS)
4,805 lbs [2179 kg] (4WD ROPS)
5,335 lbs [2419 kg] (2WD cab)
5,470 lbs [2481 kg] (4WD cab)
665 lbs
   / How much does a Kubota M7040 cab weigh? Just the cab. #4
Could be lighter components or less components in the engine or transmission.
Why are you worried about 300 lbs?
Not really worried but will be at max weight and I just like to know what I've got.
   / How much does a Kubota M7040 cab weigh? Just the cab. #6
What are you using to haul it with?
I'd haul that with a goose neck minimally with 3x 6k axles with a 1 ton diesel dually with 4x 15k load binders with 5/8" G70 transport chains securing it.
Have 14,000 lb bumper pull trailer with 10,300 lb Tundra limit and that's all I ever use for similar. I can haul 7,300 tractor and if tractor has weights or whatever I like to do the math. It not a commercial thing, just a local ag thing. Still, I stay compliant and safe.
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2005 Toyota 7FGU35 8,000lb. Straight Mast Propane Forklift (A55973)
2005 Toyota 7FGU35...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2006 PETERBILT 379 (A58214)
2006 PETERBILT 379...
HUDSON BUTLER 95" X 18' PINTLE HITCH TRAILER (A52708)
HUDSON BUTLER 95"...
2018 Ariens Ikon 52in Zero-Turn Commercial Mower (A56857)
2018 Ariens Ikon...
