John Deere 110 TLB ISO to SAE John Deere to Cat conversion
   / John Deere 110 TLB ISO to SAE John Deere to Cat conversion #1
FunHouse
Allentown, PA
John Deere 110 TLB
I switched my JD 110 TLB from the John Deere controls to Cat controls today. I thought I would post for those interested.
1. Park on a level surface and chock the wheels.
2. Shut the tractor off
3. Let the backhoe to the ground and relieve the pressure by operating the controls full travel with the machine off.
4. Locate the valve assembly just below the backhoe controls
5. Disconnect the 2 houses for the boom from the valve assembly
6. Disconnect the 2 houses for the dipperstick from the valve assembly.
7. Remove the fittings that are left in the valve assembly and switch the top ones for the bottom ones. Do this to both sets of hoses.
8. Place the boom hoses into the Dipperstick side and tighten
9. Place the Dipperstick hoses in the boom side and tighten.
10. Start tractor and check for leaks.
   / John Deere 110 TLB ISO to SAE John Deere to Cat conversion #2
I'm not quite sure what it is that you did or why....but it does sound interesting. How did it work out?
rScotty
   / John Deere 110 TLB ISO to SAE John Deere to Cat conversion #3
He changed the control pattern for his backhoe controls.
   / John Deere 110 TLB ISO to SAE John Deere to Cat conversion #4
Some construction equipment allows changing controls with a switch, rather than having to move hoses.
   / John Deere 110 TLB ISO to SAE John Deere to Cat conversion #5
I did this a few years ago with my No. 7 backhoe. I unbolted the valve stack and switched the two valves's order in the stack. ISO pattern is just not "intuitive" and I can't dig worth a crap with ISO controls.
   / John Deere 110 TLB ISO to SAE John Deere to Cat conversion #6
One thing wrong with doing it this way is your circuit reliefs are different for boom and crowd circuit.
   / John Deere 110 TLB ISO to SAE John Deere to Cat conversion #7
This would work also but Deere sells a kit to do this with out taking the valve section loose.
   / John Deere 110 TLB ISO to SAE John Deere to Cat conversion #8
Sorry, I should have been more clear. I did this to the No. 7 backhoe on my 955. I am not aware of kit for the 955. Re-ordering the valves was very easy and only took about 30 minutes. I know this post is about 110, but I was just commenting as an expression of my dislike for the ISO pattern.
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
2016 Nissan Sentra Sedan (A56859)
2016 Nissan Sentra...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
2003 Ford E-250 Passenger Van (A56858)
2003 Ford E-250...
