Snow Equipment Owning/Operating Getting Ready
/ Getting Ready #1
PHPaul
Downeast Maine
Kubota B2650 with cab, Pasquali 986
I've been planning to do this for a couple of years now. Between a gravel drive and town/state salted roads, I was getting quite a bit of surface rust on my Pronovost Puma 64 blower.
I was hoping to take the impeller off but not really counting on it as they're usually corroded in place to the point that it turns into a major project in itself. Imagine my surprise when it came off just by a little wiggling and pulling!
Driven sprocket on the auger was getting noticeably saw-toothed so have a replacement on order and a new length of #50 chain cut and ready to install.
Sanded all the rust spots down to bare metal, buffed out the edges with a 3M Scotchbrite disk on a die grinder, hit it with some Rustoleum Rusty Metal Primer. That's the spot coverage in the pictures, it got an all-over second coat after that.
Little damp out, but when the weather (and the paint) dries out a bit, I'll hit it with a coat of red.
/ Getting Ready #2
For parts that are known to corrode together, like the impeller and shaft, I’ve had good luck with anti-seize.
/ Getting Ready #3
Kinda hard to believe old man winter will be knocking on the door soon. :confused2:
Agree about getting attachment ready now than repair when wind howling snow drifting.
/ Getting Ready #4
And by doing it now you get to work with your overhead door open!
/ Getting Ready
Yes indeed. I plan to apply Never Seize on the impeller shaft and on the splines for the auger drive shaft.
/ Getting Ready
Yup. Had a minor stupid attack and didn't bother to take the car out of the next bay before sanding/grinding on the blower. Car is supposed to be metallic gray, had sort of a pink sheen to it when I took the Mrs. shopping yesterday. :eek::confused2:
/ Getting Ready #7
This reminds me of when I rebuilt my McKee blower a few years ago. I also had to reline the impeller housing though. It was worn out from 30 to 35 years of blowing a gravel road.
Something you might consider doing, it looks like your blower has a flat plate at the top of the shoot. Find some thin wall pipe, split it and weld it to the flat plate. I did that with mine and it sure made a difference in how far it would blow the snow and how much loose snow was blowing back on me.
/ Getting Ready #8
Hello PHPaul,
it would be worth your while to check and see if they offer an extended chute for your snowblower as it would get almost all the snow dust away from you when there is no wind.
/ Getting Ready
Are you saying eliminate the corners, as shown in red?
/ Getting Ready #10
Yup, but I opened the pipe up so it carried up the sides too. The snow was traveling up the shoot, hitting the deflector and deflecting all over. The pipe kept it more contained so it was a smoother transition from the shoot to out the end of the deflector.
/ Getting Ready
Interesting. I'm sitting in a nice warm cab so it's not a huge issue, but I might try it just for grins.
/ Getting Ready #12
Blowers are expensive and certainly worth the time you are putting into the paint job. My Luck Now blower sat outside for many years, and got painted last year. I was dreading a rattlecan or brush job, so I decided to invest in an air sprayer.
As far as rounded chutes... they make all the difference in the world. Luck Now uses 12” round chutes getting the powder further away before it’s all over the place.
/ Getting Ready #13
Hello PHPaul,
Extended as in taller, or extended as in a longer snout on the deflector? If you mean extended as in taller, DONT DO IT. Our Loftness came from a municipality with a 6' tall "truck loader" chute on it and cutting it down a couple of feet greatly reduced the number of clogs that we get in the chute and made it throws snow significantly farther.
I will have to try that, I actually have a piece of HDPE up there which made a big difference but I may try putting another piece sideways to simulate rounded corners.
Aaron Z
/ Getting Ready #14
The extended chutes they offer are smaller in height so they are not that tall.
/ Getting Ready #15
::confused:: the extended chutes are smaller than what in height?
Are you saying that they are shorter than my "truck loader" chute was? I would hope so, it was a pain to try to fit under the trees.
Aaron Z
/ Getting Ready #16
Yes shorter than your truck loader chute.
/ Getting Ready #17
I just ran across a picture that will give you an idea on putting the split pipe at the upper end of the shoot. It isn't very good but may help.
/ Getting Ready #18
Nice work
Have you thought about adding rubber to the impeller? I know a few guys that havr done this to walk behind units and notice a big difference in how far the snow goes and less chute clogging.
/ Getting Ready
Nice work
That was actually one of my goals.
When I got the auger off so I could get at things, I checked the clearance all around the impeller and the largest gap I found was perhaps 1/4 of an inch, and tighter than that in most cases so I decided it wasn't worth the effort.
It has always thrown a pretty good distance anyway. I am going to try the half-round idea tho.
John Deere 772-A Grader (A62679)
John Deere 772-A...
KUBOTA M108S TRACTOR (A64277)
KUBOTA M108S...
2007 KENWORTH T800 TRI/A ROLLOFF TRUCK (A59914)
2007 KENWORTH T800...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
