New Branson tractors
/ New Branson tractors #1
ptsg
Super Member
Portugal
Branson F36Rn - Agria 8900D
Just found a Facebook page from a Lithuanian dealer where they show some new stuff from Branson.
First is the Branson P110. The numbers suggests that it will be around 110HP. They say it is already available in the US. I can't find anymore specs or info about this. From the pictures looks like it has Adblue. Pictures were shared in January. This model might go front 80HP to 110HP.
26240754_1990550851213188_2178152377575595663_o.jpg26233038_1990550807879859_904125484199633059_o.jpg21106705_1934181826850091_2147957047421009199_n.jpg26220389_1990550854546521_1665522333745170014_o.jpg26220870_1990550804546526_2289008219193330859_o.jpg26232778_1990550861213187_8474787750004274421_o.jpg
Then it's the "new" 2018 25 Series. Pictures were shared in May. A couple new changes, not much though. But maybe a 25 series owner can check for more changes that I'm not aware. I can see a new front grill and the tie down hooks. Don't mind the front hitch. It's a very common after market option in Europe. Some also have front PTO with this unit.
36064214_2075301296071476_1940359756388499456_n.jpg35923224_2075301162738156_7239549058266693632_n.jpg33579859_2057913027810303_2501191204306157568_o.jpg33553631_2057768894491383_5489109530186874880_o.jpg33502412_2057768811158058_6139155300042670080_o.jpg33383683_2057768774491395_6581963511977476096_o.jpg33359179_2057768801158059_4651584306102140928_o.jpg36276656_2081908655410740_8403379225754599424_o.jpg
Last it's the new F series with Cab. The F series is a European model equivalent to the 15 series in the US. Don't know if they will make it for the 15 series though. Looks like it has a new front grill, a badass factory LED light bar, new control layout mostly for the key switch, PTO switch and hand throttle. All the good stuff that comes with cab as in AC, radio and so on. Hydraulic side link which I don't know if it's standard or aftermarket. Totally different dash. They relocated the light and flasher switch and also the Shuttle lever. Tilting steering wheel. The new style front diff vent.
42058697_2157981134470158_2275559800399986688_o.jpg42084560_2157981194470152_8200157900342034432_o.jpg42129593_2157981114470160_6126963588696375296_o.jpg42145047_2157981131136825_4959461722386595840_o.jpg42150704_2157981051136833_6337563092397850624_o.jpg42171851_2157981041136834_3837474955952390144_n.jpg42178480_2157981034470168_8297707701534720000_o.jpg
/ New Branson tractors #2
The fuel filter is different than my 3725. There's an electrical switch near the frame in front of the fuel filter (pic 3 first row of 25 series) that's not on mine. Looks like a system cutoff of some sort. Those may be european market differences. Also the hood latch is different- mine has a pull rod on the tractors' right side.
The switch is a battery cut off switch and the Fuel filter may or may not have a heating element incorporated, as this is very common for the eastern European countries.
As far as the hood latch, looks like it uses a key now? At least the sticker indicates that.
/ New Branson tractors #4
Thanks for the pictures;
The 110 looks like kind of a cross between my 8050 and a 7845.
Much of the cab control layout looks like the 8050, the rear axle and 3 point looks like the 7845.
/ New Branson tractors #6
The 5025C in those pictures has mechanically self leveling BL25R loader, unlike the BL25R and BL200 branded loaders currently available on the US market 25 series.
The self leveling loaders are quite common over here. Every Branson loader I saw here, was a self loading one. Even the aftermarket ones that are mounted in the middle ROPS tractors are self leveling. I don't think I ever saw a non self leveling loader.
/ New Branson tractors #9
I've noticed that before when browsing the UK, Australian, and Global Branson sites, and when watching youtube videos of Aus/Euro/UK Bransons. Self leveling loaders, higher horsepower models, and different quick-connect 3 point and front hitch/PTO setups. Makes a US market fellow jealous. :D
/ New Branson tractors #10
Wish my 15 series had a tilt steering wheel.
