New mower blades or just sharpen them?
   / New mower blades or just sharpen them? #11
I can't believe the OP is passing up a chance to buy a new tool :laughing:
I went with a modestly-priced bench grinder with a stand - so I can use it outside and not get all the metal dross on the garage floor. Serves me well, and my GR blades go many seasons if sharpened once per.
   / New mower blades or just sharpen them? #12
I have a grinder I used if the blades get a nick from our abundant rocks, then finish it off with a file. Several years ago my belt sander just happen to be on the work table and I have not gone back to using anything else since then. I have two Kubota mmm decks, two push mowers and a 42" bush hog. The belt sander is perfect for everything. It does a perfect job and certainly saves time.
   / New mower blades or just sharpen them? #13
Blades don’t need to be razor sharp. A grinder is plenty good enough. A file touch up isn’t needed.
   / New mower blades or just sharpen them? #14
Same situation, have bench grinder. Belt sander was out. Belt sander is really good for sharpening mower blades. Check out the horrible fright belt/disc sander. I have an old crapsman (same thing). You will wonder what you did without it!
   / New mower blades or just sharpen them? #15
What works for me best is I put blade in vice upside down first. I use a 9" grinder , 80 grit paper to lightly sand backside flat.
Flip over, lightly sharpen cutting edge.
I use an inexpensive balancer like this.
The grinder takes off very little material so it can be sharpened a lot.
   / New mower blades or just sharpen them? #16
Like others I use a 4 1/2 inch angle grinder, but I don`t bother to balance them or take them off the machine, I just guess at taking the same off them all. As for the blade in the picture, I would leave it, it looks OK.
   / New mower blades or just sharpen them? #17
Here's one of mine this one has 3 summers worth of grass cutting. I don't have a wheel grinder and i'm not sure how hard it would be to get them balanced. They are $15 each new and a cheap wheel grinder is around $50 so buying 3 blades would cover a wheel grinder plus a balance tool.
Your yard must be about 10 square feet if you got 3 seasons on that blade. Mine will look like that after one mowing due to all the rocks and crawfish/ant mounds that I have to mow over plus I mow over 6 acres so that is a lot of grass to cut .
I wouldn't sharpen it yet if I were you unless you already have it off the mower, then just a little touch up on the last couple of inches should do it.
I do have some files, but they aren't used to sharpen anything. I cant believe anyone with a mower doesn't have a 4.5" grinder. They are such a handy tool. With cutoff wheels, they can be used for cutting off steel or with abrasive wheels, sharpening/shaping etc. A harbor freight 4.5" grinder can be had for under $30 for the top of the line model with paddle switch. For lawnmower blades, I like to use the sandpaper grit wheels (some folks call them "tiger paws") rather than a hard abrasive wheel. It gives a smoother surface and doesn't gouge like a hard wheel can but sharpens very fast. I would use a hard abrasive wheel if I was working on a bush hog blade since you would need to remove a lot of metal.
actually it's 3 acres, i have a HF near buy so i can just buy a grinder will any HF metal wheel do the job?
I know nothing about blades so i have no idea how it should look if you sharpen it. Do i need to get rid of all the little nicks? Does it need to be a nice straight edge?
That is just the end blade i think the center blade will look worse i'm always mowing dirt since it likes to scalp the yard.
It has not been cutting so good so maybe the deck is just clogged up.
   / New mower blades or just sharpen them? #19
I bought my B1750HSDT and 60" mower new in the spring of 1993. I'm currently on my second set of blades but the original ones are still OK. I changed to high vacuum blades several years ago.
For over 20 years I sharpened the blades with a file. I still sharpen the walk behind trimming mower blade with a file.
I would usually go through a file each season sharpening the 4 blades and good files have become expensive and hard to find so last year I let my dealer sharpen/balance the 3 Kubota blades for me. He charged me $20. A decent 12" mill file costs around $15.
The pictured blade should be sharpened but need not be replaced.
I've been mowing for over 60 years with various equipment and have never balanced a blade in my life.
SDT
   / New mower blades or just sharpen them? #20
The way I do it on our riding mower now, is when I think it is time to sharpen the blades, I replace the old blades with new blades. And quickly get the mower back in service. Then, later I resharpen the old blades in my spare time. When the new ones I installed are ready to be sharpened, I simply swap out the dull blades with the old sharpened blades I kept as backup. Once again I sharpen the ones I just remove later so they are ready to do a quick change when needed. This way I always have a set of sharp blades ready to install when needed. If the dull blades I just removed are beyond there usefulness, I just order a new blade or blades over the internet (usually cheaper than buying local), but my mower has got a fresh set of sharp blades on it while I wait on new ones to arrive or sharpen the old ones. Granted, it does not take long to sharpen blades, but once I'm under the mower, I can change out the blades pretty quickly and be off mowing instead of taking the extra time to sharpen blades or worse, be forced to run to the store to buy a replacement blade I did not realize was damaged or worn beyond repair until took it off.
Head Gate (A57454)
Head Gate (A57454)
2020 Big Tex 22GN25T5 30' Gooseneck Trailer, VIN: 16V6X2528L6050344, Tandem Axle, Wood Deck, Bad (A59076)
2020 Big Tex...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2004 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2004 Ford F-150...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
