Transparent aluminum
/ Transparent aluminum #2
High performance applications in the military field - - hmmm.
/ Transparent aluminum #3
/ Transparent aluminum #4
FWIW, the molecule in the movie was pretty complex too, not a single element metallic crystal.
/ Transparent aluminum #5
Pretty remarkable, but the lead in is very misleading. I'm not surprised that you could take an oxide of Aluminum and mix it with other chemicals and make a transparent compound; "Aluminum metal" and this compound are two entirely different things. It's like saying that a diamond is transparent Carbon.
Actually, that was a mistake on my part. I believe that diamond (albeit with impurities) is "pure" Carbon, but just a different crystalline form than the black forms of Carbon. Metallic Aluminum is different from Aluminum in combination with Oxygen.
/ Transparent aluminum #6
Al2O3 has always been transparent.
It's the stuff that keeps pure aluminum from corroding. It's on all aluminum. You just don't see it ;-)
/ Transparent aluminum #7
/ Transparent aluminum #8
Sounds kind of like the stuff they found at Roswell.
/ Transparent aluminum #9
Do you want that in red or blue?
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
2017 KOMATSU D61PXI-24 CRAWLER DOZER (A64279)
2017 KOMATSU...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
5' Bush Hog (A62613)
(2) UNUSED 16.9-24 TIRES ONLY (A64280)
(2) UNUSED 16.9-24...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
