I was told it is a bad idea...hold my beer!
   / I was told it is a bad idea...hold my beer!
Yep! My driveway is 35°....my trail is mostly 45° ....I'm cutting into a knob/very big hill that is mostly 60°
Driveway maxes at 70% grade/ 35° slope.
Trail is currently 100% grade/ 45° slope....I'm hoping to reduce this when i get to where I'm going by taking dirt from the top and lengthening out the bottom part.
My knob is insanely steep which is the reason for the trail.....which is why I bought the tractor. You cant literally hold your hands out and touch the ground in front of you as you hike up it.....okay for me...but not ok for most people.
   / I was told it is a bad idea...hold my beer! #103
Tiptoo, I forgot about this, but reading your thread jogged my memory. Don't know if you have ever visited "Falling Waters" the Frank Lloyd Wright home.
My wife toured the house, I went on a walk about on the grounds. They have various trials through steep terrain and to divert the water, they placed (recessed) guard rail sections flat on the trail at a angle. Water comes down the hill, hits the channel in the guard rail and water gets diverted.
Figure if it is good enough for Frank"s land, good idea for others.
My wife toured the house, I went on a walk about on the grounds. They have various trials through steep terrain and to divert the water, they placed guard rail sections flat on the trail at a angle. Water comes down the hill, hits the channel in the guard rail and water gets diverted.
Yes!! That's a great idea. I'm a ways away from tackling the water issues as I'm still just cutting a rough trail. Just crossing my fingers for now.
   / I was told it is a bad idea...hold my beer! #105
Awesome reading this. Love the fact that you are doing almost everything that everyone else is telling you not to do! too funny.
I'd also be worried about starving the engine of oil at extreme angles. ;)
I asked a question earlier today...then just reread most the posts....and saw your very true statement....I'm starting to get worried.....any solutions to not starve the engine of oil???
   / I was told it is a bad idea...hold my beer! #107
Yeah. Don't go on hills that are steeper than the oil pickup.
Sounds like a flippant comment, not meant to be. But other than having the engine set up for acrobatics like they do with airplanes, there's just some limits that you shouldn't exceed. A lot of it has to do with how the oil pan is shaped, where the pickup tube is located, and where the oil return ports are located in the head, too.
Best thing to do is find the engine manufacturer's data on what angles the engine can be operated on.
   / I was told it is a bad idea...hold my beer! #108
I would also supplement the oil pressure idiot light with a oil pressure gauge so that you can see exactly where your oil pressure is when you're operating on such slopes. Then you can see better if the engine starts to starve for oil and know what kind of a slope you can run on.
Aaron Z
   / I was told it is a bad idea...hold my beer! #109
I believe my tractor manual says to add an extra quart of oil above full for steep operation,,,
might want to check the manual.
   / I was told it is a bad idea...hold my beer! #110
An Oil Accumulator might work for you
Auto racers use them as well as some hard core offroaders
Great for short periods of oil starvation
ones like Accusump claim 15-60 seconds of low pressure coverage (protection) before the sump needs to pick up more oil and recharge the accumulator.
They work good as pre lubers also to virtually eliminate start up wear.
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
2006 Ford F-350 XL Superduty (A47477)
2006 Ford F-350 XL...
2014 Ag Spray Schaben Sidedresser (A55301)
2014 Ag Spray...
