2017 Kubota BX23S - Transmission Filter Part Number ?????
   / 2017 Kubota BX23S - Transmission Filter Part Number ????? #1
BX23S-1
No Clue
Kubota BX23S
Hi folks... question.... anybody know the correct transmission filter part number for the BX23S loader/backhoe tractor...?
I have to stop at the local dealer and get one for my 1st 50hr service, just want to make sure they are giving me the correct transmission filter...THANKS guy`s...!
   / 2017 Kubota BX23S - Transmission Filter Part Number ????? #2
k1211-82320 I think.. That's the # in the maintenance kit for the trans filter..
KUBOTA OEM BX FILTER MAINTENANCE KIT BX23S BX1880 BX2380 OIL FUEL AIR HYDRAULIC
   / 2017 Kubota BX23S - Transmission Filter Part Number ????? #3
Yup that's the correct #.
Thank you guys very much!!!!!!
I wish we had a sticky/posting for all the filters and correct lubes, but if there is one, i haven`t found it yet.
Well... here is the transmission filter/#number they gave to me at the dealer: HHK20-36990
Is there a documented place i can check this transmission filter part number..? Because this number isn`t the one posted in the thread.
EDIT:
I went directly to KUBOTA USA and found the correct transmission filter...
the one the dealer gave me (#HHK20-36990) is the correct transmission filter for the BX23s TLB model.
   / 2017 Kubota BX23S - Transmission Filter Part Number ????? #6
My mistake, I posted the air filter assy.. The Filter HHK20-36990 is the correct part # hydro filter..
   / 2017 Kubota BX23S - Transmission Filter Part Number ????? #7
OIL FILTER HH150-32430
FUEL FILTER 12581-43012
AIR FILTER K1211-82320
HST FILTER HHK20-36990
HYD FILTER K2581-36520
Thank you! I did finally find all the filter numbers.
I believe the K2581-36520 is actually a metal screen
   / 2017 Kubota BX23S - Transmission Filter Part Number ????? #9
Sounds about right..
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
