3725 Third function hydraulic
/ 3725 Third function hydraulic #1
TomIre
Gold Member
College Grove, TN
Branson 3725
Spent about an hour today picking up a couple of rocks with my stock bucket on my FEL. Became apparent I'm going to need a grapple and a third function hydro control.
Any tips or suggestions on the third function? OEM or third party? Assume there is a way to put it in/on the fender mounted joystick but not sure how.
Any advice much appreciated!
/ 3725 Third function hydraulic #2
The factory kit is a diverter instead of a true third function. There are plusses and minuses to each. It has a replacement joytstick handle that has the switch in it. Same shape but made from hard plastic.
If you get a generic kit or make your own as many people have done, and want a clean install of the switch in the joystick you'll need to buy an alternate handle that has a place for the switch. A few people have cut their factory handles and stuffed a switch in them but with ours being a sort of soft material I'm not sure that'd be durable.
I'm still operating my EA grapple using a 3rd rear SCV which is mounted on the fender. Not as good as a diverter/3rd function but the lever's a lot closer to the joystick than the factory remote levers next to the seat.
/ 3725 Third function hydraulic #3
We offer this custom kit by WR Long, which is by far the most popular and well received aftermarket kit in history. 180 customer reviews on our website.
WR Long custom 3rd function hydraulic kit
Take $50 off if you order with a Wicked Grapple, which is our ever popular highly functional work of art!
Travis
/ 3725 Third function hydraulic #4
Travis, the WR Long is popular with your customers partly because it is what you offer. Also, it is one of the only 'all-inclusive' DIY kits available.
Neither of those makes it a really good piece of equipment, but with enough sweat and extra purchased parts I think I may be able to get it installed. I still won't like it, but function means more than liking it.
/ 3725 Third function hydraulic #5
Travis, does your WR Long custom kit come with brackets and fittings to match the Branson 20/25 series? From watching the video I thought that fitting it to the tractor was up to the purchaser.
/ 3725 Third function hydraulic #6
Yes, the kit comes will the necessary brackets and fittings to fit the particular tractor/loader. You'll just be responsible for install and will not need purchase extra parts.
Travis
Ted, planned to call you and didn't get to it today. I'm somewhat capable with tools, engines, but far from even competent. No hydraulic experience at all. Think I'd be able to install your kit on my own?
What is a SCV? Would you mind posting a pic of your install - lever, fender, etc?
/ 3725 Third function hydraulic #9
I say yes. Most people say it's easy as pie. Our parts guy, Rick H, has installed countless WR Long kits and is a champ at offering assistance if you need it!
Travis
/ 3725 Third function hydraulic #10
Selective Control Valve. Often called a remote.
Here's a pic of the third SCV on the fender. The valve is one of those that lets you put the handle at different positions.
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2015 FREIGHTLINER  2500 4X2 SPRINTER VAN (A59906)
2015 FREIGHTLINER...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2020 Sellick S80 (A60462)
2020 Sellick S80...
2014 FORD F-150 (A60736)
2014 FORD F-150...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
