Buying Advice Need to find the right equipment to mow a steep grade
   / Need to find the right equipment to mow a steep grade #21
For that small of an area, I wouldn't be looking at a multi-thousand dollar piece of equipment. That's only 18,000 square feet, or .41 of an acre.
you're underestimating how much I despise walking behind a 20" push mower. haha. I'm going to borrow a buddies RWD honda and try it out late this week or early next week.
   / Need to find the right equipment to mow a steep grade #23
Hire it done. Spending thousands to do what’s probably a $30 job doesn’t make sense.
   / Need to find the right equipment to mow a steep grade #24
Get something that can be used by multiple people doing multiple jobs. Snow removal, hauling brush on trailer, pulling wood splitter, are a few things my wife does with the x744. When dad broke 5 ribs, she was the one using their x749 mowing the steep areas too.
   / Need to find the right equipment to mow a steep grade #25
url
   / Need to find the right equipment to mow a steep grade #26
Good one! I like goats too!
   / Need to find the right equipment to mow a steep grade #27
Any of the front deck 4wd's will do what you want to do. Quickly and easily.
   / Need to find the right equipment to mow a steep grade #28
Keep this in mind! With those slopes you MUST make sure your mower has a pressurized oil system and a sump that will keep the oil flowing. Most push or riding mowers use a splash oil system and on those slopes their engines will burn up in a very short time.
   / Need to find the right equipment to mow a steep grade #29
Seriously though, an older Steiner or JD with diff-lock will do the job and then some. You can also put brooms and snowblowers on both of them
CASE INTERNATIONAL 3950 - 21' DISC HARROW (A52708)
CASE INTERNATIONAL...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
JOHN DEERE 6615D MFWD TRACTOR (A52708)
JOHN DEERE 6615D...
Rooster Artwork (A55758)
Rooster Artwork...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2017 Freightliner Derrick Digger (A55973)
2017 Freightliner...
