Truss Boom Build
/ Truss Boom Build #1
deanprince23
British Columbia, Canada
2017 kioti ck3510
Hi everyone. any advice for building a Truss Boom to lift trusses up onto walls? I have a idea how to do this.......
1. Skid Steer Quick attach build
2. 8' square tube welded onto skid steer attach point
3. 2 1/2" x 48" hydraulic cylinder
4. 5' square tube inside the 8' square tube
5. attach hydraulic cylinder to both square tubes.
6. paint and live happily ever after...
i know I can buy a pre built attachement, however, they are very expensive and i dont see a whole lot to build one.
any thoughts or concerns?
thank you and i look forward to the feedback.
/ Truss Boom Build #2
I would make a rigid or pin-locked telescoping boom, put an electric winch at the bottom with a pulley at the top. Set the loader on the ground for stability, winch the truss up.
Bruce
/ Truss Boom Build #3
I bolted a 16' 4x4 onto my pallet fork frame.
/ Truss Boom Build #4
Why do you need to hydraulically telescope it? Couldn't you just make it like an inexpensive engine lift boom assembly where you cross pin the the two tubes at the extended length you need?
/ Truss Boom Build #5
Welcome to TBN Dean, I built a little bigger version of what your describing. A few pics for idea's.
/ Truss Boom Build #6
Took the bucket off my mini-ex and strapped a wood 6x6 to the boom and we used it to set the neighbor's floor trusses. He hired a crane for the roof.
enhance
/ Truss Boom Build
ha. yea, that would work but i really like hydraulics, thanks for the input though
/ Truss Boom Build #10
How do you size up the tube that way there isn't any play and what about wearing the steel thin in a few years?
/ Truss Boom Build #11
Hope the gap is a standard width and weld in bar stock for shims. Grease it.
/ Truss Boom Build #12
Some of you guys way over build things! All I did to lift rafters is chain a pipe onto the bucket of my 430 loader. I welded an angle iron to fit over the lip of the bucket, welded on a brace on each side and ran a chain around the bucket.
Later a buddy of mine borrowed it and added a piece of angle iron to hold two chains to spread them and then used it to lift tin up to the roof. I used it for my tin and it sure saved a lot of lifting.
/ Truss Boom Build
that sounds great, my plan is to build a solid practical boom and hire it out to my son and son in law who are both house builders. they spend a good deal of money to rent cranes etc. plus i like to weld things :)
/ Truss Boom Build #14
Yeah, I get that. Would hydraulic side to side be more useful than in and out?
/ Truss Boom Build #15
Looked briefly at that extendable boom and a thought came to mind.
Why not an ATV 12 volt winch with a pully arrangement to extend the slider?
Much cheaper and easier to assemble.
Winch would be bottom end mounted (short power cables) and pully at top to pull up and out the inner tube.
Naturally tubing sizes would be selected to allow cable passage (and shimmed with perhaps brass or HDPE sliders) but should be doable.
I think 3" tube inside a 4" would leave adequate space for a cable and sliders.
Being intermittent usage the tractor battery would keep up easily.
/ Truss Boom Build #16
thats exactly what i'm talking about...you got any plans for that boom? it looks great.
I just put it together with what I had laying around. 4570Man pretty much nailed the details. The outer tube is 6x6 - 1/4" wall and the inside extension is 4x4 with a heavy 3/8" wall. The cylinder was from a guy that "scrapped" out stuff from Grove Crane, he had the best junkyard I've ever seen. It was alway's a several hour visit walking around his place and "hmm, what could I build outta that?" IIRC I gave him about $100 for 2 of those cylinders! Still have one kicking around.
/ Truss Boom Build #17
Best idea I ever saw was a local contractor had a long 3 " steel pipe that was slipped over the end of a hay spear on a farm tractor. He then used chains to fatten it to the corners of the spear frame. Worked slick for lifting 24' roof trusses. Here is a picture of it in use. W Jones
/Users/Jones/Pictures/Willie's phone.photoslibrary/resources/proxies/derivatives/06/00/6b8/UNADJUSTEDNONRAW_thumb_6b8.jpg
/ Truss Boom Build #18
Lets try this again.UNADJUSTEDNONRAW_thumb_6b8.jpgUNADJUSTEDNONRAW_thumb_6b8.jpg
/ Truss Boom Build #19
If you want something cheap and easy to build for 1 job, before I had a loader, I just set an apprx. 12 inch x 20 ft tree trunk in the ground next to the foundation, or it can be set in the center of the building to cover more area, chained about a 20 foot smaller tree about 2 1/2 -3 inch dia. on the small end just above the foundation, attached some pulleys including one at the base, pulled the trusses up with the car and swung them into position. Here's a link to the best photos I could find -- at a model railroad site, but the full size looks the same.
Railroad Line Forums - The Gallery: March ?13 "Cranes, Hoists & Derricks?
Smiley
/ Truss Boom Build #20
If you want a really sketch version of a truss boom, try two 2x6 screwed together into a "T" and strapped to the forks.
2013 Nissan Sentra Sedan (A61569)
2013 Nissan Sentra...
2019 KUBOTA SVL75-2 SKID STEER (A62129)
2019 KUBOTA...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63118)
Neckover GL24-2-7K...
2021 KUBOTA SVL95-2S SKID STEER (A62129)
2021 KUBOTA...
Brent 420 Grain Cart (A63118)
Brent 420 Grain...
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
