Buying Advice lifting abilty in compacts- looking for a second smaller tractor
/ lifting abilty in compacts- looking for a second smaller tractor #1
WVfarmin
Mahindra 6530
Hi,
Due to a change in my husbands work, this winter I will be tasked with putting out round bales for our cattle. Our rounds are prob 800-900 lbs dry. I have to confess I am terrified of his 6530 Mahindra. Its huge, has gears and levers sticking out everywhere, and as soon as you let off the clutch you are moving. Yes, I know, I'm a wimp. But the fact our barn has literally inches between the pole beams and the rear wheels requires one to be really good spearing and taking out bales. I have visions of me taking out the barn at 1mph....until he got used to the tractor, HE took out a few posts...ahem. needless to say, while that tractor is awesome for brushogging fields fast and heavy work, Id really like something smaller and easier to maneuver, as well as less compaction to the ground in the winter mud/freeze. the ruts that thing makes are enormous. There are a few 3010 kubotas in our area but I wonder if they can lift a larger round bale without falling over on their nose, esp since our are stacked. I also am considering a smaller Mahindra, like a 1526, but again, wonder if it is too small. I basically don't want to spend a ton on a second tractor, and we don't need another beast tractor, but just one big enough to put out hay and do the lighter easier work and be hydrostatic so I have less to freak out over when I am by myself.. I also would not mind helping hubby brushog, two tractors would make shorter work of it. We live in WV and NOTHING is flat. So it is a big learning and confidence curve for me ..oh and my day job is in a hospital where I see all the guys who flip their tractors...every year at least 2-3.......so I come by my wimpiness honest. Thanks!
/ lifting abilty in compacts- looking for a second smaller tractor #2
I would think if I were to be lifting 900lb bales on a constant basis safely, I would be looking for a lift capacity of 1400lbs. So maybe, around 40hp in hydro with sufficient ballast.
/ lifting abilty in compacts- looking for a second smaller tractor #3
Used forklift in the barn. Big tractor in the field.
Bruce
/ lifting abilty in compacts- looking for a second smaller tractor #4
My new Branson 4015 is a pretty small tractor, about the size of the 3000 series Kubotas, yet with the new BL150 loader it can lift 2200lbs to full height. Pretty amazing really.
The 15 series Branson sounds right up your alley. The hydro-max transmission automatically brings engine speed up or down based on pedal, perfect for what you will be doing.
/ lifting abilty in compacts- looking for a second smaller tractor #5
I would have a lot of use for this myself, my next tractor will have auto throttle..
/ lifting abilty in compacts- looking for a second smaller tractor #6
I had auto throttle on my Kubota and I didn’t like it at all. What do you guys find appealing about it?
/ lifting abilty in compacts- looking for a second smaller tractor #7
An L3010 kubota is too small to lift a 900 pound round bale. I think a LA724 or 7 whatever the newer model is is the smallest kubota loader to do the job.
/ lifting abilty in compacts- looking for a second smaller tractor #8
I was thinking it would be handy for loader work to not have the rpm's high all of the time, I do mostly loader work with my tractor.. What did use you tractor for and why didn't you like it?
/ lifting abilty in compacts- looking for a second smaller tractor #9
It wasn’t proportional to the pedal travel. It was at nearly full rpm at 1/4 of the pedal travel used. And it reved to like 2700 rpm regardless of work load. I much preferred to set the rpms around 2000 unless more or less power was needed and adjust as needed. Overall I liked my Grand series tractor a lot better than the standard series.
/ lifting abilty in compacts- looking for a second smaller tractor #10
Just learn to run the big tractor. Put some seat time in. You’ll get it. If it’s beyond you, you’ll know after a couple days.
/ lifting abilty in compacts- looking for a second smaller tractor #11
I see, the little Massey 1526 I tried was proportional to pedal travel so I figured all of them would be the same but I guess not.
/ lifting abilty in compacts- looking for a second smaller tractor #12
The Mahindra 1526 HST or now the 1626 HST is a great little tractor. Has over a 1500lb loader lift capacity at pins. It should handle your 900lb bales with ease.:thumbsup:
Probably a little over $20K though. :(
/ lifting abilty in compacts- looking for a second smaller tractor #13
Mine was like a 2008 model. Maybe they’ve changed since then.
/ lifting abilty in compacts- looking for a second smaller tractor #14
Bruce
Yup, appropriate tool for the job. Or store the bales outside.
How far do you have to carry bales? Just in the barn? Near the barn? A long ways from the barn?
/ lifting abilty in compacts- looking for a second smaller tractor #15
Just learn to run the big tractor. Put some seat time in. You値l get it. If it痴 beyond you, you値l know after a couple days.
Agree w/ this post. Put a few bales outside and throw a tarp over them until you acquire a feel for the tractor. Post a few photos of hay and tractor storage areas ? Let the TBN experts view working conditions. ????
If finances are no object, hire someone qualified to use your tractor to feed the livestock.
/ lifting abilty in compacts- looking for a second smaller tractor #16
Would like to agree with just getting comfortable with the large tractor,
But can't...
If the operator with tractor experience had trouble navigating in the barn without damaging the building, It will be even harder for a really new operator when the amount of room to maneuver is limited.
I really like my 8000+lb as set up tractor for everything including moving large square bales into the barn, but once inside it is another story.
Have to agree with the folks suggesting a heavy built but small footprint hydrostat tractor with stout FEL specs.
A forklift may make sense IF the floor is concrete and not in an area where freezing and ice are a possibility. It will also not be much use for other common in barn jobs like stall cleaning if that is going to be part of it's duties.
ps. when we had multiple properties we had to mow, it was really nice having 2 tractors going, and was fun knocking the job out as a team with the wife running one of the tractors.
/ lifting abilty in compacts- looking for a second smaller tractor #17
But can't...
Or a medium sized skid steer. They’ll blow the doors off a tractor for cleaning a barn or stacking hay. They probably won’t do good for delivery in a wet field but use the bigger tractor for that.
/ lifting abilty in compacts- looking for a second smaller tractor #18
Never thought of the ease and maneuverability of a skid steer for that job, that’s a good idea..
/ lifting abilty in compacts- looking for a second smaller tractor #19
I’ve got a big skid steer and my buddy has a smaller one. His is about 7000 pounds and would handle round bales with ease. When comparing skid steers to tractor keep in mind that rated operating capacity of a SS and full height lift at the pins on the tractor isn’t the same measurement. Tipping load of a SS and breakout force on a tractor will be pretty close to the same measurement.
/ lifting abilty in compacts- looking for a second smaller tractor #20
Skid steer will get into tight places for sure, I had a New Holland L778 wheeled skid steer and sold it.
Noisy, hard to see behind- and rough riding. It had no problem moving and stacking good sized rounds or pallets in a tight space. I just prefer a tractor.
Sister has a Bobcat Tracked T-250 Smooth Quiet - much nicer to run, a real step up for sure.
The Skid steers tend to rut things up after making turns to.
Some people Absolutely Love them
Something that a person really needs to operate and compare to a tractor to decide for themselves.
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
