TN75D Operators Manual
   / TN75D Operators Manual #1
Fguard
Auckland, New Zealand
NH TN75D 2003
Hi I have just purchased a 2003 nh75d with 6900 hours and are looking for an operators manual for servicing.
As I have seen commented here the workshop manual (which I purchased a PDF copy of) provides no maintenance info i.e. location of grease nipples, drain plugs, how to replace fluids etc.
There is the odd operators manual for sale on eBay but I would need to get it shipped to New Zealand.
Would anyone have a PDF operators manual? Im also happy to give a PDF copy of the workshop manual to whoever wants it.
   / TN75D Operators Manual #2
:welcome:
To TBN Fguard. You came to the right place to help.
If anyone on here can help you, they will gladly.
Cheers, it will go to its retirement as a boat tractor. Has spent all its life mowing lawns and road berms.
Needs a bit of a tidy up, has been sitting for 5 months outside.
   / TN75D Operators Manual #4
In the picture it doesn't look that bad but pictures don't show that much detail.
Does everything work and did the do proper maintenance?
   / TN75D Operators Manual #5
I have a TN75D Operators Manual that I no longer need. I do not hav ea pdf copy How can I get it to you
Andy
Hi Mike, don't know yet! it has been sold on the basis everything is operational. Has been owned by a corporate mowing contractor who lost a contract hence the disposal.
They have siliconed perspex over the rear and front lower panel glass, so that can be removed. Plenty of surface rust on the front diff/axle housing and rear hydraulics, specs on inside of wheels. Bit of rust on the floor of the cab, seat ripped.
Looks likes its been sitting outside when not used, but should clean up OK. Some more pics attached.
With a fat rear hopefully it works great on sand hauling a 6m glass boat off the beach!
   / TN75D Operators Manual #10
View attachment 569483View attachment 569484
View attachment 569485View attachment 569486
Thanks for the additional pictures. Looks normal shouldn't be any major problem.
UNUSED FUTURE SE61-61" HYD SWEEPER (A57193)
UNUSED FUTURE...
Kubota BX25D (A53317)
UNUSED FUTURE BS72 72" HYD BOXBROOM SWEEPER (A57193)
UNUSED FUTURE BS72...
Texaco Antique Fuel Pump Art (A55853)
Texaco Antique...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
