Good morning!!!!
   / Good morning!!!! #81,121
I grew up in northeastern NC, and my parents were from northern Alabama, so I know what he means. I was just calling attention to a situation that aggravates me, people moving to the country, then complaining because it’s like the country, then trying to make it like wherever they came from.
That’s a MAJOR rub here. Wanna tick off a local, just interject, “but back in California....” seems too many people decide what they need to change what made the place attract them in first place. One of the reasons I don’t miss where I grew up in Maine, now mini Mass.
   / Good morning!!!! #81,122
Pressure washed the green off the front of the garage. Had to use extension ladder and run the wand one handed. Glad that is done. Then cleaned grill, and pressure washed some of the pieces.
Our HS football game was postponed last night because of lighning, now the Ohio State game is in lighning delay.
Stepped out to get mail, hot and humid. Storm clouds building up.
   / Good morning!!!! #81,123
If it takes an hour of running before the symptoms, manifest, it's no wonder the dealer couldn't find the problem. No way they're gonna take that much time with it.
Next time it stalls, get your ear right up next to the fuel tank cap and listen for a woosh or hiss when you open it. If you hear one, the fuel tank vent is blocked.
If that's not it, heat build up could be the problem. Does it have an electronic ignition? The control module or rectifier could be getting hot enough to malfunction, or a connection somewhere is faulty and acting as a diode when hot. Get a can of spray freeze (I think it'd just carbon dioxide) at an electronics shop and shoot it at any suspect component to see if it fixes the problem.
Sounds to me like you've exhausted your options at the dealer, so maybe it's time to go over their head and try to find someone at Kubota at a higher level that can help. I bet there's a thread or two here on TBN where someone has done that and would tell you how they did it.
Good help is hard to find these days...:duh:
BEF, glad you're feeling better, you might be your own worst enemy when it comes time to rest instead of work... I totally understand.
RIP, I believe that because you can pull out the choke, and it keeps running, that there is no malfunction of spark....A carburetor has it's float bowl, where the gas should stay at a correct level when everything is working/flowing. If you turn off a petcock that stops gas flow, your engine will continue to run for a while depending on load. Then when it starts losing it's gas, you can hit the choke to pull the last bit of gas out of the float bowl (which is what you're doing it seems). What kind and brand of engine does it have? Does it have a small vacuum operated fuel pump? these have a small diaphragm that will use the engine block pulses to pump fuel. Usually they last, but you might have gotten some debris into yours or something. You can put some translucent fuel line and a filter on to actually see what's going on.
Ron, I will add conduit contractor to your resume.
I lived in an HOA. Some things good, some not so good. When the cat people get put in charge, the dog's suffer, and vise versa. But all in all, they are designed to protect everyone's home values.
Been staying with my mom since yesterday. She had her gall bladder removed, and since she's elderly, they let her stay overnight for observation. All is well, we are home now, and she's up and about quite a bit. They put CO2 inside of you to inflate you while the surgeon does the laparoscopic surgery. This was part of her pain that they kept her overnight.
Drew, thanks for the tour.
How Much Does the New Yamaha 425 Cost?
We’re told that retail pricing for the Yamaha XTO 425 will start at $44,250 for the 25-inch shaft in right rotation and $45,185 in left rotation. The 30-inch shaft will retail for $45,000 (right) and $45,935 (left). The 35-inch model will be $46,120 (right) and $47,060 (left).
Ouch. About $100G for a pair.
   / Good morning!!!! #81,124
73F partly cloudy.
Outside at day break...trimming,dump run,qiuck trip to town for critter food,mowe lawn and front field,now kicking back for the rest of the day.
While mowing front field couple fox pups kept close eye on me just inside the woods line.
Notice Mrs. made BIG of dry beef gravy and hash. :licking:
Enjoy the evening all.
   / Good morning!!!! #81,125
Drew,
Weren稚 you aware of your neighbors when you moved in?
sure Randy, I was, and I was too good at being facetious here, I was joking....just to make the point where some neighborhoods could use some better zoning enforcement, not less. I moved to hillbilly heaven and I'm right where I want to be.
I believe what no one likes is the "last ins", those last few residents who want to rewrite history for everyone before them. No. Go back to NYC...
My guest just started and ran all four of my tractors. Pics coming, fun time had by all.
   / Good morning!!!! #81,126
Same thing on the Outer Banks.
   / Good morning!!!! #81,127
HAHA. Our integrator keeps saying we should do things because that’s how the plant in Georgia does it. They get a little irritated when I say “we ain’t in Georgia”.
   / Good morning!!!! #81,129
Did a day trip to Salado TX today. Found a wall of art items with something for just about everyone on the morning thread. Well at least for RNG. IMG_2232.JPG
   / Good morning!!!! #81,130
Did a day trip to Salado TX today. Found a wall of art items with something for just about everyone on the morning thread. Well at least for RNG.View attachment 569383
Hmmm, that Coke bottle cap sign would look good over the bar (if I had a bar!).:laughing:
LOT: (2) Cargo Van Shelving Units, (2) Steel Shelves (A59076)
LOT: (2) Cargo Van...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
2009 Ford Crown Victoria Passenger Car, VIN # 2FAHP71V79X115619 (A57453)
2009 Ford Crown...
Auger Skid Steer Attachment (A56857)
Auger Skid Steer...
SPRAY TRAILER (A58216)
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58216)
PALLET OF 15 4X8...
