Could really use some help with finding problem with L3400 Kobota. As a new member
   / Could really use some help with finding problem with L3400 Kobota. As a new member #1
errobinson
Kobota L3400DT
Hello good people,
I have a L3400 Kobota that will not start. It will "klick" on the right side of the engine and the electrical system drops power. I have replaced fuses (all tested okay) and the components under the dash because they would buzz when key was turned on. The head lights are very dim when turned on if they light up at all. The battery is fully charged. Any ideas?
Thanks in advance.
err
   / Could really use some help with finding problem with L3400 Kobota. As a new member #2
Hello good people,
Thanks in advance.
err
Check the main ground wire from the Neg side of the battery to the frame...
   / Could really use some help with finding problem with L3400 Kobota. As a new member #3
And that might mean removing the cable and scraping or sanding/filing it, the nut/bolt and frame to clear any corrosion before tightening it again. A connection can look good even if it isn't.
   / Could really use some help with finding problem with L3400 Kobota. As a new member #4
Like /pine mentioned, it sounds like a corroded or loose connection.
Assuming the battery is good.....fully charged does not mean good battery.
   / Could really use some help with finding problem with L3400 Kobota. As a new member #5
Measure voltage on the battery posts directly on top of the posts while assistant attempts to crank the engine. If the voltage drops below 10 volts than the battery itself is likely defective. If the voltage stays near 12 then move out with the voltmeter leads to the starter bolt to see if there is any drop across the positive battery cable. Starter cables can look perfect on the outside and be totally corroded on the inside of the cable under the jacket. So you must determine if it is a battery problem or a cable and its associated connections problem.
   / Could really use some help with finding problem with L3400 Kobota. As a new member #6
Welcome to TBN. We've moved your post to the Kubota Owning/Operating forum. You should get more replies here.
   / Could really use some help with finding problem with L3400 Kobota. As a new member #7
I have an L3410 HST. Simple things first - pull battery cables, clean and reattach tightly. Even if they seem secure. I had a no-start situation and assumed some major problem but that was all that it was - cleaned and reattached and it started right up. Could also be a bad battery - since you are getting weak power - I also had that situation - it would not hold enough of a charge to start. If that is not it - maybe it is the neutral switch. That also happened to me once when it would not start. It was difficult to access (under the forward-reverse pedal on my HST) but when I did I found a wire had worked loose. Repaired that and it started right up. Good luck.
   / Could really use some help with finding problem with L3400 Kobota. As a new member #8
The head lights are very dim when turned on if they light up at all. The battery is ̶f̶u̶l̶l̶y̶ ̶c̶h̶a̶r̶g̶e̶d̶
Battery or connections are U/S.
   / Could really use some help with finding problem with L3400 Kobota. As a new member #9
Enmark Z Spray (A53316)
Enmark Z Spray...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
LOT OF PIPE W/ PAD ON END (A58374)
LOT OF PIPE W/ PAD...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
3" X 4" GAS POWERED WATER PUMP (A52708)
3" X 4" GAS...
