Here it comes (finally)
/ Here it comes (finally) #1
MikeR 2018
Central Pa
Kioti CK2610 HST with FEL, Rotary Cutter, Box Blade and HLA Grapple
Well, I can finally add a tractor to my profile. I am getting a Kioti CK2610 with Loader, Brush Mower, Box Blade and HLA Grapple Tomorrow, they deliver everything except the grapple which should come in a few days.
I will be taking off the next 6 days to play in the dirt.
Thanks to everyone in these forums for educating me. I look forward to learning more.
/ Here it comes (finally) #2
Congrats on your wise choice of tractor! Enjoy it. I'm especially interested in your HLA grapple. I have one of their snowplows and its excellent. What model did you get?
Thanks.
It is the HLA RR-GLD 60 inch Light Duty Root Rake w Grapple. It is what my dealer caries and recommends. I have dealt with him for years and trust his judgement. I will gladly tell you what I think of it after I get it - for what that is worth. I have nothing to compare it to.
/ Here it comes (finally) #4
Congrats and welcome to the pack! Anxious to see pics and some of your work!
/ Here it comes (finally) #7
Well it will take some learning before I accomplish much.
I don't feel I accomplish much with mine. Cut brush and use the bucket to haul around small bush and grass cuttings. A ton of info on this site which gets me thinking but then there are also a ton of different opinions on how to do things which gets me :confused2: LOL I'm sure you'll pick up things quickly!!
/ Here it comes (finally) #8
Thanks.
I do have a few questions about your choice of grapple regarding it's size/weight for your tractor's lift capacity; especially since you are, IIRC, a novice to tractors. You sacrifice what you can lift/carry, (payload) with a heavier rake/grapple on the end of your FEL. The capacity of your FEL's lift is reduced by the weight of the grapple, plus your load carried in it. The highest weight you can theoretically lift is at the FEL's pins. Your rake choice at 60" with grapple, is over 400#s. It is mounted in front of the pins, so your capacity is reduced even further.
Here's what I suggest. Consider getting the 48" rake and grapple combo at 48" it is lighter, smaller to maneuver around objects, likely just as strong as the 60" unit, (same metal and thickness of the tines, etc.), I suspect, but it does not limit your payload as much, and would likely cost less too.
For instance my GR-20 Log Grapple, made by Igland, in Finland, weighs 350#s off the top of my head, and is much smaller footprint than a rake in width, only 24" or so, but it is also less capacity drain on my DK-40, which has a FEL capacity of around 2800#s! It is intended for logs primarily, which is what I use it for. It's definitely not a rake, but it does what I need it to do, and serves me well.
I'd check what capacity you have, on your FEL; what you intend to do with it primarily, and possibly discuss it further with your dealer as to what he thinks would suit you best. PM me if you want to discuss further.
Also, do you have front mounted hydraulic lines with the tractor to run your fork/grapple? Looks like you will need them...
Hope this helps.
/ Here it comes (finally) #9
:thumbsup: and congrats Mike,looking forwrd to pics.
:thumbsup: and congrats Mike,looking forward to pics.
Well i have been busy playing with it the last few days. Learning a lot. Clearing the back woods. I was incorrect - it is the brush hog that is on back order, not the grapple. Probably a 48 inch might have been better but the die is cast. So far, I am happy with it. So here are a few picks.
I am going back out there as soon as the sun comes up. Talk to you in a couple days :)
/ Here it comes (finally) #11
Good looking grapple Mike. Don't worry a moment about the 60" grapple - if 12" increase in width and weight were going to kill us - we would all be dead already.View attachment 569405 This is my Land Pride GSC 1560 - 60" - 820 pounds. People wondered why I got such a heavy duty grapple. Maybe most don't deal with the gigantic rocks and logs I move but after four years of intense use the only "unfortunate" thing - some of the powder coat paint is starting to chip off.
An example of the jobs I do - over at the neighbors house - restructuring and grading his parking lot. His parking lot was a depression and filled with water at every rain - mud, slop & even getting stuck several times. The top tines work as scarifiers and the rear blade drags, grades and levels. Pulled down an entire mountain of fill dirt - scarifying with the top tines and dragging out and leveling with the rear blade.
Other work - I move large chunks(10 foot x 32" dia) of my Ponderosa pine. Its right at the upper limit of my "system" - 3200#. And I don't care if my grapple weighs 820# or 400# or something else - nothing I can put on the end of my FEL will lift a 120 foot Ponderosa pine that is 32" in diameter at the butt cut.
"A man had got to know his limitations"
/ Here it comes (finally) #12
Mike - let me show you something else you should consider - seriously. I see by your pics - you have an OEM grill guard. Here is what a little expanded metal and some time did to mine. There are numerous horror stories here on TBN of sticks, stobs, limbs etc, etc puncturing grills, radiators, batteries etc.
I don't weld - local weld shop and a kid with a great imagination built this up for me. He thought I should paint the "tongue" red - I think that would be a little over the top.
WOW! Thatis nice.
/ Here it comes (finally) #14
Does the kid want to make any more of those? I would love something like that.
/ Here it comes (finally) #15
That's a nice guard.
/ Here it comes (finally) #17
I agree, nice set up Mike you will love your Kioti. You are now one of the pack. :thumbsup:
2019 PETERBILT 567 (A65643)
2019 PETERBILT 567...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
Keota MFG Bale Mover (A65640)
Keota MFG Bale...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
Farm Hand Silage Wagon (A65640)
Farm Hand Silage...
