Oil & Fuel CK35 square sockets for drain plugs?
/ CK35 square sockets for drain plugs? #1
Breton48
Does anyone make square sockets for the engine oil and transmission fluid drain plugs on a CK35?
/ CK35 square sockets for drain plugs? #2
Square drive sockets (female) and bits (male) are a fairly (un)common tool made by most automotive tool makers with a comprehensive line. I believe I bought a set from Sun-ex, reasonable and certainly adequate for drain plugs. Measure the plugs to see if they are SAE or metric; some of the smaller sizes are usable in the other standard, but be aware some manufacturers (Kubota, anyway) mix standards on the same plug. I buggered a 9mm x 1/4" NPT plug using a 3/8" socket, replaced with a 3/8 x 1/4 NPT plug from the hardware store.
/ CK35 square sockets for drain plugs? #3
Are they a weird size? I've usually been able to use the drive end of a 3/8" ratchet or extension with no socket on some machines.
/ CK35 square sockets for drain plugs? #4
Quite common to use square holes, on newer equipment it's often a metric dimension.
The Kioti CK35 has male drain plugs, so no holes and the best tool to take the plugs out would be a square drive female socket. As for the plugs, yes their size do seem a bit weird: on the two engine oil drain plugs, a 18mm wrench is too small, a 19mm is too big. The 19mm wrench might work, but there is a lot of slack. I tried a 3/4" wrench, as that measures between 18mm and 19mm. It did not fit. All the wrenches I have are either too small or too big to fit the transmission drain plug. I'll measure the plugs and see what I come up with.
I have used crescent wrenches to undo those plugs, but I would much rather use something more appropriate.
I found a six point socket in 3/4" size that fits near perfectly the engine oil drain plugs. Still looking for a better solution than a crescent wrench for the transmission plug.
/ CK35 square sockets for drain plugs? #7
Just a note. If possible when replacing a drain plug, get a steel plug versus a iron plug. A steel plug is much more used friendly.
/ CK35 square sockets for drain plugs? #8
Kioti does use some 'weird' sizes on things like grease zerks, and I'm fairly sure that the drain plugs may fall into the same, not quite metric or SAE. It may be some British or other hardly ever used other odd size, and if anyone figures it out please let the rest of us know!
/ CK35 square sockets for drain plugs? #9
Use a 3/4 to 1" adapter, backwards, with a 1" open end?
/ CK35 square sockets for drain plugs? #10
I was thinking of suggesting trying a 12 point around the size you suspect, but I thought that might sound silly.
/ CK35 square sockets for drain plugs? #11
A 12 point socket or a 12 spline ("Universal") may fit, in that is it slips over the square post and resists turning by hand. In my experience the leverage of the (ratchet, breaker bar, sliding "T" bar) handle is often enough to bugger the corners of a stubborn plug. Although crescent wrenches are often frowned upon, such an adjustable wrench with pressure on the thumbwheel to hold it tight is often the "right" tool. A dab of never seize on re-insertion will reduce subsequent stubbornness.
Well, I measured and I think a 1 1/4" or 32mm six point socket should work.
/ CK35 square sockets for drain plugs? #14
What you need for square plugs are 8 point sockets.
What is an 8 Point Socket Used For - YouTube
/ CK35 square sockets for drain plugs? #15
Take it off once with an adjustable wrench, then
1. file or grind 2 sides a tiny bit so your 3/4 inch wrench fits. Then get an 8pt 3/4 socket.
or
2. weld a hex nut onto the end of the plug.
or
3. get a new plug with a standard sized head.
Bruce
OK... To recap: for my CK35, both engine oil drain plugs are square in shape, and male. The best fitting tool I found for those is a six point socket in 3/4". The rear drain (for hydraulic fluid) plug has six sides, and measures 30mm. I went to Sears this morning to buy a six point socket for that plug, and ended up with a combination wrench (open/12 point). That's all they had in stock. I will use the open side, as it fits the plug perfectly.
I will research 8 point sockets. Never heard of them before.
/ CK35 square sockets for drain plugs? #17
^^ Have you ever seen one of these? I have never used one and cannot recommend them, but for a situation where there isn't any great amount of torque involved, they might just work. I've seen them in a few places and under different names too.
Or they could be total junk.
Depending on the price, I might be willing to try one! Could be useful when one encounters a truly oddball fitting... if it works!
UNUSED WOLVERINE QMP1-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
UNUSED WOLVERINE SB72-72" ROCK BKT (A62131)
UNUSED WOLVERINE...
2021 Ram 5500 4x4 Palfinger PSC 8029 4 Ton Crane Mechanics Truck (A61568)
2021 Ram 5500 4x4...
HE WASHING MACHINE & DRYER (A62131)
HE WASHING MACHINE...
