Bad gas?
/ Bad gas? #41
Yes! My brother (shade tree mechanic) had never heard of it either. He was gonna help me "rebuild" the carb. This was cheaper AND easier. I did learn how to remove/reinstall a carb, so win-win.
You're certainly smarter than me! My small engine repair shop has one that they use to clean those tiny carburetors. So - I decided to buy one from HF and do my own. Bonk! They may work for some people, but for me, I still had to disassemble the carb completely then use the ultrasonic cleaner.
Honestly, I could not tell you that the ultrasonic cleaner did one single thing for me... other than lighten my wallet of $80 to HF. But - if you'd like to buy a slightly used one at a very reasonable price - just ping me :)
Soaking the carb overnight in carburetor cleaner, then blowing it out with an air hose is the old tried and true method.
/ Bad gas?
I imagine the dealer has a heavier duty model but I can ask him if you're interested. Hmm, I see in the reviews of the HF model, folks do say it cleaned carbs. ?
/ Bad gas? #43
GWWT - post #37 - talking about the dealer putting your carb in an ultrasonic cleaner. Ultrasonic cleaner is small tub sitting in small package - about size of your normal household toaster. The tub is filled with some form of water soluble cleaning solution. Chuck the part in the tub of cleaning solution - turn on the machine. Makes a humming noise - that's the ultrasonic sound waves.
I worked at a place that had a fairly large ultrasonic cleaner. Tub was 1' by 2' by about 10" deep. It was used to clean tooling. Finally had to have a meeting with all the guys RE - the ultrasonic cleaner.
You will be charged $5/hour to have "whatever" cleaned in the ultrasonic unit. There was a backlog of guys waiting to have their carb parts cleaned. An ultrasonic does a great job of cleaning parts. The $5 supposedly paid for all the cleaning solution being used.
/ Bad gas? #44
I have found a mix that seems to work for me (YMMV), Seafoam and Lucas Injector cleaner. I put a measured amount (about a squirt of Lucas, bit of Seafoam) and run it. I have used both over the years, but starting in about 2010, I found this mix works on what I have.
/ Bad gas? #45
Problem with the HF model is that it has a 5 minute built in timer. It hardly has time to warm up in 5 minutes. And for extended cleaning, one has to stand there and punch 'start' every 5 minutes. Dumb feature.
QA Pallet Forks (A64127)
QA Pallet Forks...
Case IH 4200 Combo Mulch (A66285)
Case IH 4200 Combo...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
2022 EZ-GO ELITE...
