Electronics Gurus--Off Topic Question
/ Electronics Gurus--Off Topic Question #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Wondering if the solid state relay shown would be appropriate to power a clothes washer? It would be used in conjunction with the drain monitor to kill power to the washer if the drain overflows.
DiversiTech WS-1 Wet Switch Flood Detector: Household Alarms And Detectors: Amazon.com: Industrial & Scientific
My concern is the "leakage" of the relay as opposed to a mechanical relay and how that might affect the electronics in the washer control. Also thinking that a heat sink might be required?
Any suggestions appreciated including alternative devices. I just happen to have the Crydom on hand.
Thanks in advance.
/ Electronics Gurus--Off Topic Question #2
When it comes to line voltage stuff I'm a big fan of physically isolated components. Relays, transformers and the like. Solid state stuff does behave differently, even the optically isolated variety.
/ Electronics Gurus--Off Topic Question #3
It's rated 25A so I assume it would be fine but I'm no mechanical engineer. You'd have to make sure you broke the hot and not the neutral for safety of anyone working on the washer that might think it's dead is the only issue I can think of.
Vvanders has a valid point also about being isolated........Mike
/ Electronics Gurus--Off Topic Question #4
This relay could be mounted on wall high enough to not get wet. then a transformer out put of 24volts to sensor should the water fail to drain. Have used this type to alarm when the chillers froze and then defrosted causing water to flood the floor.
Your washing machine using 120 volts would be no different than a power fail when running.
ken
/ Electronics Gurus--Off Topic Question #5
Enclosed relays with contacts rated for 110V and sufficient amperage are cheap and commonly available. Match the coil voltage to whatever your control device puts out. Myself, I would rig up a box, basically an extension cord type thing with the relay inside. Cord to plug into the wall outlet, relay inside the box and a new outlet mounted to it. Plug the washer into that new outlet. That way, you don't have to alter the washer in any way.
Those relays aren't very big, so you may be able to use a standard double gang surface box (one of the grey outdoor types).
/ Electronics Gurus--Off Topic Question #6
Thanks in advance.
Here’s food for thought...
Fail of the Week: Solid State Relay Fails Spectacularly | Hackaday
I personally wouldn’t be buying these on eBay...
Most industrial guys I know favour mechanical relays with high voltage coils to ensure positive engagement. I.e. don?t choose to switch 120VAC loads with 5VDC coils
/ Electronics Gurus--Off Topic Question #7
Why don't you skip the electronics and have the washer empty into a holding tank upstream from the drain? When you prepare the next load, if the holding tank is not drained you don't start again until it is.
/ Electronics Gurus--Off Topic Question #9
I've never heard of a drain for a washer backing up. The washer has a lint/foreign matter trap in front of the pump. Has this been a problem in the past?
Thanks for all the ideas and suggestions. They are all appreciated and I will respond to a few of them:
Ken--My concern is the few milliamps of leakage current that passes thru even when the relay is "off". The washer would see this current but may not be a problem.
Diggin It--I was kind of thinking of the small box idea and I agree on the availability of mechanical relays.
Mikester--Your "Fail of the week" is enough to scare me.
WVBill--Good find. I would need a long extension cord as the washer is on ground floor while the drain is in the basement floor.
ChiefBodie--I thought about the holding tank near the drain in the basement but if the drain plugs there would still be water on the concrete. With that in mind, I did build a holding tank of sorts. It consists of a 6' length of 6" PVC drain pipe to serve as the vertical part of the drain connection between floors. It will hold about 8 gallons of drain water and has holes at the top end so that the water can't back up to the first floor and flood. At the bottom is a 5/8" orifice which sounds too small but handles the washer pump's output well.
The water would overflow the top of the 6" riser if the orifice ever plugged which would be fine as the water would drain down the outside of the riser and down into the floor drain.
If the floor drain ever plugs, however, I need a way to shut off the washer pump and hence the need for the sensor operated relay in the power to the washer.
The floor drain is normally capable of easily handling the flow 99%+ of the time but there's that one time. :)
/ Electronics Gurus--Off Topic Question #11
You wouldn't need a long power extension cord for that appliance device, you'd just need to extend the sensor wires, which appear to be just two-wire. Simple lamp cord would suffice.
/ Electronics Gurus--Off Topic Question #12
There's also a device called the Water Cop. It shuts off ALL WATER to the house if a leak is detected.
/ Electronics Gurus--Off Topic Question #13
I'd go with an appliance rated cord. Or do you mean for the sensor?
/ Electronics Gurus--Off Topic Question #14
Big fan of SSRs. I have been meaning to put our water pump on one so I can remotely control it from the house. No appreciable loss. Relays use power and burn up.
Thanks again, WVBill, for the link to the WaterWatcher. That sure "cleans up the act". Will just lengthen the sensor leads per MossRoad. I thought about that but wasn't sure if it might affect the sensor "sensitivity".
/ Electronics Gurus--Off Topic Question #17
Sorry, but after seeing your pictures I have to ask. It would appear you are you draining the washing machine into the basement footer drain/sump pump. Why is the washing machine drain fed into the basement floor drain?
Good question. The other half of the basement if finished and that's where all the plumbing is. It would be difficult to plumb over the furnace ducts and thru the joists to the finished side. Access is very limited but not saying it couldn't be done.
By the way, the floor drain is still functional. I used an inverted toilet flange to let "surface water" drain thru the slots in the flange. The basement is always dry but want to keep it that way.
/ Electronics Gurus--Off Topic Question #19
I didn't really look at the pictures or think about the extra tank mentioned. Why? Because I thought it was typical to dump the washer into the laundry tub and the OP was concerned about that overflowing if the drain clogged. I've had that happen.
So, OP, do you have a laundry tub beside or near the washer?
We presently have no laundry tub after moving the washer and dryer upstairs to a spare bedroom from the basement.
We're getting older and carrying the laundry up and down the stairs was becoming an issue.
2013 RANCO BELLY DUMP (A67714)
2013 RANCO BELLY...
Land Pride RCR186 (A64912)
Land Pride RCR186...
2021 Unused Paladin QH1 3 Point Quick Hitch Tractor Attachment (A66734)
2021 Unused...
Rears PT 1000 Gal Orchard Sprayer (A64911)
Rears PT 1000 Gal...
John Deere 6330 (A64911)
John Deere 6330...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
