Converting my pin on loader to a skid steer quick attach system
/ Converting my pin on loader to a skid steer quick attach system #21
Nice job!
You should weld something on to connect the two new quick connect plates. This can help with both hyd cylinders moving together too. Not just what ever one has the least pressure on it.
I think it would add stability, looking at what ATI, WR Long and others offer they usually have a connecting bar. FEL-qa2.jpg
/ Converting my pin on loader to a skid steer quick attach system #22
Seams to me whatever the those quick connects are hooked to that becomes the connecting bar tube brace and or plate to both rams.
With all the threads on here about twisting the connecting tube, I would not put one on.
If you retract the curl cylinders all the way before you hook up the attachment, it should work OK. If one side moves first, it will stop when it contacts the attachment plate. When the other side contacts the attachment plate, raise a little and curl back to seat the quick attach, then latch the levers.
Thanks guys, I am now going to tackle the forks, I would have today but it was just plain nasty humid and I was a bit lazy and busy with work stuff.
My buddy has twisted his tube on his Kubota, I do not plan to put anything, my Massey 1540 I had didn't have anything and it worked OK, I think you have to get used to not moving them much once unhooked.
Funny how plans change! I broke down and bought a set of 2K forks today. I really need them to pull the cylinder out of my Lull.
It's too hot for me to be standing bent over welding , it;s time I don't have right now. I will eventually do something with the spare plate I have. Any ideas? LOL
/ Converting my pin on loader to a skid steer quick attach system #25
How about a trailer mover:
/ Converting my pin on loader to a skid steer quick attach system #26
My ssqa trailer mover is very handy. Likewise my ssqa mobile hoist. Those would be my suggestions.
Thanks for the props and suggestions. I don't really need a trailer mover. I'll come up with something. I do know where there are some new old stock bucket that can be had fairly cheap, I didn't really want to do the work to convert one of them but since I have the plate and want a wider bucket...hmmmm
I only have a 60" and would like a 66". The farm store has a pile of nos pin on buckets.
/ Converting my pin on loader to a skid steer quick attach system #28
I converted my bucket on my L3800 and it was the most worthwhile thing I've done. I constantly switch between the bucket and pallet forks. In fact I might actually use the pallet forks more.
My pallet forks are from Titan and have a bale spear and receiver hitch.
/ Converting my pin on loader to a skid steer quick attach system #29
Yeah, I'm glad I did it, used the forks today to round up all of my 4x6 and 6x6 pieces of cribbing for tomorrows project. I am going to remove the cylinder from my Lull and rest it on the forks.
You all are bad influences on a fellow! LOL
Funny how there is always something we need/want.
I don't have time to deal with it at the moment so I have some time to think on it. A new quick connect bucket is 629, a new pin on bucket is 300 and i have a 100 dollar plate. Is it worth it? I should probably just buy the bucket that is ready to go. I know the plate will get used eventually. :)
Luckily I don't need a new bucket right away so there's that.
ETA: I am a small contractor and I know I will be using the forks a lot on the smaller jobs where the Lull isn't really needed.
Well I had to put the forks to use today :)
Used them to take the Lull cylinder out and rebuilt it today and re installed it. It's 14'-8" long :eek:
This one is taking it out, I wish I could have taken many more but between the rain, grease and humidity and the fact that my daughter was coming for a brake job at noon I didn't really have time.
This one is after the rebuild and getting it ready to go in
/ Converting my pin on loader to a skid steer quick attach system #32
:thumbsup:
/ Converting my pin on loader to a skid steer quick attach system #33
And so it begins, I finally got around to ordering some pieces to convert my pin on loader to skid steer quick attach system.
The first part of the puzzle arrived today
Where did you fine those SSQA plates?
Hey it looks good.
/ Converting my pin on loader to a skid steer quick attach system #36
I've been looking at those same adapters on ebay. What did you think of the quality are they well built ?
Yep, for 120 bucks you can't go wrong. Just note that when they arrive the handles are not on properly and you will have to change things around to have them right. I believe it makes for a more compact package for shipping.
2023 Case TV380 (A62177)
2023 Case TV380...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2025 Hercules 14 Gun Safe (A61569)
2025 Hercules 14...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
2019 GALYEAN...
