Backhoe Best way to get grease in a stuck fitting.
   / Best way to get grease in a stuck fitting. #21
With that boss being so dry i would use a flap drum sander on it to make sure the grease has some room to get out both sides of the pin.
   / Best way to get grease in a stuck fitting. #22
I just figured they must be full! HA HA
Recently I purchased a tool that you fill with grease then place over the fitting and hit with a hammer. Haven稚 got a chance to try it yet...
The angled style don't hold up well to that treatment.
Now a "smoke hammer" (O/A torch) That works frequently. just don't spoil the fine wire spring that pushes on the ball. BTDT! leaves a hole... ;-)
   / Best way to get grease in a stuck fitting. #23
I find they work better if you fill them with WD40 or a penetrating oil. If it's not the grease zerk itself, it's often that the grease itself has dried out and hardened up. WD40 can loosen it up.
   / Best way to get grease in a stuck fitting. #24
KROIL.... works MUCH better than WD-40, on almost everything!
   / Best way to get grease in a stuck fitting. #25
The best I've found for freeing stuck parts is Blue Creeper, but all we are doing here is loosening up dried up grease. WD-40 works fine for that and is easy to get. I'm sure Kroil would work as well or better. Kerosene or diesel would also work.
   / Best way to get grease in a stuck fitting. #26
Often a fitting won't take grease cuz it has been neglected so old grease and dirt build up between the fitting and pin. You can 1) remove the fitting and dig/drill the crap out. 2) burn it out. 3) I bought a tool that consists of a piston and cylinder. I put diesel fuel into it, place it on the fitting and strike it several times with a hammer. It usually clears it out. Look up Lincoln Impact Fitting Cleaner.
WOLVERINE QUICK ATTACH DOZER BLADE (A57193)
WOLVERINE QUICK...
(2) 10" X 12# X 70.5" (1) 10" X 12# X 104" I BEAM (A57192)
(2) 10" X 12# X...
John Deere 5100M (A53317)
John Deere 5100M...
2012 Chevrolet Colorado Ext. Cab Pickup Truck (A55852)
2012 Chevrolet...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55853)
2023 Fat Truck...
2015 Dodge Charger Sedan (A55853)
2015 Dodge Charger...
