Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,341
Looks like AT&T is cutting my tower off. Stuck the unit in my truck and drove towards town. About 9 miles from the house it woke up.
EDIT: Could just be a coincidence but I downloaded the AT&T Mark the Spot APP to my Verizon phone and reported the data loss through that this morning. Reset the Mobley tonight and it is connected and is flying.
This time I hung it in the window so it's inside the blinds so that should help keep the heat off of it.
It is working wireless through my GL-AR300 router. For some reason my cameras will not connect so I may have to reset those and start from scratch which is another PITA.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,342
My situation took a turn for the worst. Mobley lost connection again and I have no way to figure out if it's the unit or tower signal. I am thinking it's the tower.
In the meantime something has changed in the router so I can no longer access my network cameras, Chromecast, or anything else on my home network. I can still log into my router so I don't know why the cameras are not talking to it. It seems it changes channel every time. I have tried setting the channel and also tried the channel setting on auto to no avail.
I guess I will try calling AT&T on Monday and see if they can get me going. After I get a stable internet I reckon I'll have to set everything back up on the network.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,343
My Mobley update:
I've been using the Mobley since late winter 2017. For most of that time it has pulled 22-33 Mb/s and been a very solid Internet connection for us. In early June the speeds dropped noticeably and I started experiencing bad latency and halting throughput. Eventually realized that the AT&T signal in general at my location was significantly worse than it used to be. Family uses AT&T cell phones and they all are down to 1-2 bars now on a regular basis instead of the 3-4 we used to get. My Galaxy S6 phone which used to pull 55-60 Mb/s at home now is lucky to get 25. The Mobley dropped from the 22-33 level to 6-9 Mb/s.
I don't believe any of the problem is related to the Mobley. I suspect that either AT&T has a problem with the closest tower we connect to, made changes that altered the tower's power, or perhaps changed a contract with a 3rd party tower operator and now we're having to connect to a tower further away. In any event it sucks because it really hurt the data connection.
However, I did learn of an app that can tell you tower signal strength so I got that and started searching around the house for best signal. Turns out that 6 feet from where the Mobley used to sit on top of my desk is a window and right in that window the signal is a lot better. So much so that after moving the Mobley to the window it's now back to getting 30 Mb/s and the bad latency and halting has disappeared. Makes me wonder what I could have gotten in that position back when I was getting better speeds on the desk? :) So, at this point I'm back to happy with the situation and hopefully I can continue to ride the cheap/unlimited Internet boat for a while longer.
I did recently learn of a 3rd party offering the same basic service as the Mobley. They use what appears to be a better cell modem that is intended as a fixed base station and also has built-in wifi. Still uses AT&T's cell service and offers unlimited data for $89.99/month. The device costs $300 though. Definitely not as good of a deal as the Mobley but if/when AT&T pulls the plug on unlimited data or skyrockets the price of the Mobley plan it may be a good alternative. The company is called UbiFi.
Another note on the Mobley... We routinely push well over 200 GB per month through it and have never been throttled. Since I use it in a very low population area I think the throttling is unlikely because the network is unlikely to ever be congested.
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,344
My Mobley update:
Rob
C'mon man - provide links to the app and the device.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,345
ubifi.net
Sorry, assumed a quick Google search on UbiFi would be adequate...
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,346
My Mobley is still working fine through my Asus router for $22 a month. I don't see how the Ubifi is comparable to that at $90 a month
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,347
It's comparable in that it is the same basic service. Obviously the price is not close at all. But the AT&T $20 unlimited plan cannot last forever, so when they pull the plug or jack the price sky high (which is what I said above) then it will possibly be a viable alternative.
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,348
ubifi.net
For ubifi, sure... but I think he meant the signal strength app:
What app did you use? What device did you run the app on?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,349
My Mobley is still doing great. They have never throttled the speeds on it. My service was $22.01. It went up a few months back to $23.24. I don't expect the deal to last but I will ride it for as long as I can.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,350
The Mobley plan says that you may be throttled after 20GB, Ubifi is unlimited with no throttling threshold.
I bet that you could take the SIM out of a Mobley and put it into a Mofi so you have a fixed station with built in WiFi and better cell antennas but still only pay $20/mo. You still run the risk of being throttled though.
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
2012 WILCO MACHINE & FAB INC. WILCO MACHINE & FAB INC. (A50854)
2012 WILCO MACHINE...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A51039)
2022 Quick Attach...
