CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,366
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
SL&H small Tractor Question. SAME Lamborghini & Hurlimann, for those unfamiliar. Italian beauties ;-)
If you have a SAME Solaris, or a Lamborghini Runner or a Hurlimann Prince /435 etc.
Can you get the rear lift to drop when the engine is not running? I can't on my Hurlimann Prince 435.
No position of the two 3pt control levers will let down the rock shaft. I can lift it in the float position, but not get it to droop.
With the engine running, the lift seems to operate just fine.
I've looked hard and long at the linkages and levers at the 3 pt box. I can't see anything out of adjustment.
Float is NOT at the end of the control lever travel on these tractors. The end of position travel is power down.
