What did you do to or on your Mahindra today?
   / What did you do to or on your Mahindra today? #341
Helped my neighbor get two loads (6yds each) of mulch from the county recycling facility. Dumped in his driveway then moved it to the backyard. He spread it!
   / What did you do to or on your Mahindra today? #342
Took the brush hog out for the first time since last summer. loosened up the clutch plate on the hog and spun it around to free it up. then used it with the grapple for about 3 hours. Ran real nice.
   / What did you do to or on your Mahindra today? #343
I cleaned all our covers and then covered the shoulder season wood today, tomorrow our better hardwood for this winter will get covered.
After supper I moved an old stump out of one of my plow zones for this winter, after that I grabbed three smaller loads of a mixture of sand and dirt for next to our garage.
   / What did you do to or on your Mahindra today? #344
Picked up 15 tons of 3/4 gravel for the driveway using load trail trailer and floated it with the front bucket. IMG_1142.JPGIMG_1143.JPG
   / What did you do to or on your Mahindra today? #345
I filled two bigger plastic garbage cans with sand for the winter and filled enough five gallon pails to fill another garbage can.
   / What did you do to or on your Mahindra today? #346
Put an LED bar light on at the top of the ROPS. Haven’t had a chance to see how it works.
   / What did you do to or on your Mahindra today? #348
I did more digging and work around the new garage, hopefully this will be the last of the dirt/sand we need so I can get cutting some wood.
The first thing I did was roll it.
   / What did you do to or on your Mahindra today? #349
What brand name LED bar light do you have and how did you run the wires?
It is a NiLight. I think it is just a generic light, nothing special. It is a 20 inch model. I ran the wires under the left foot pad and up the ROPS. I did not modify the ROPS in any way. Held the wires on with wire ties.
You need some hefty wire, the light pulls a fair amount of current. If you get one, get it with a wiring harnes relay.
ECR145CL VOLVO EXCAVATOR (A50854)
ECR145CL VOLVO...
2012 MACK CHU613 (INOPERABLE) (A50854)
2012 MACK CHU613...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
7021 (A50322)
7021 (A50322)
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
