Tiller or disc
/ Tiller or disc #1
OrangeToys
SW Missouri
2016 Kubota M7060HDC
Im about to put in a new food plot on over grown property. What do you suggest? I am planning on brush cutting the areas and spraying, but i need the ground broken up
/ Tiller or disc #2
Disk. On new food plot there will probable be roots and Lord knows what else. A disk should survive the unexpected better.
/ Tiller or disc #3
An M7060 can pull as Disc Harrow with pans 24" in diameter, as wide or 18" wider than the rear tires, which will cut through anything. Front gang should have notched discs. Rear gang can be notched or smooth.
Definitely a Disc over a Root-tiller with such an amply heavy tractor.
I seeded one 2/3 acre food plot with forage oats yesterday, then rolled in seed with a Cultipacker.
/ Tiller or disc #4
That's the beauty of having a larger tractor-being able to disc, etc. The roto tiller lets us with 20-30 hp compacts and SCUTs play at the farming game!
Will
/ Tiller or disc #5
Get as heavy of a disc that you can afford. An offset will cut better but not smooth as well. If you have room a transport disc is a good option. You can find them used and are typically heavier than three point versions. Look at pounds per disc as a guideline. The heavier the better.
/ Tiller or disc #6
Will
I guess you've never seen a tiller like this,
It's my tool of choice for food plots and breaking new ground. I don't even own a disc any longer, as my customers never ask for one, once they see this tiller in action!
SR
/ Tiller or disc #7
Oooh ~~ La- la.
Jealous be me.:rolleyes:
/ Tiller or disc #8
The properties I hunt in NE FL are all active timber land. Any openings that I make into a food plot always has stumps, roots and partially buried tree tops.
For me, a tiller is constantly hitting an obstruction so I prefer to use a disc.
Takes several passes and I usually spread it out over a couple months on a new spot, but it works for me.
Now, on the permanent food plots, that are clear of any debris, I will have one of the guys use his tiller if available.
/ Tiller or disc #9
It would have to be a BIG stump to be a problem for the above tiller... Big enough to be a problem for a disc too.
In fact, tillers like the above were used to till out the stumps left behind in Christmas tree farms after the tree's were cut out.
SR
/ Tiller or disc #10
I have been at it 40 years this year and just a couple of years ago finally bought a 6' 3pt tiller. Already had a Hay King brand pasture renovator that does the deep cutting first (subsoil aeration, heavy clay soil). Then it seems that the tiller and spike tooth-flexible harrow have made the rest of my tillage implements obsolete. Better results with fewer trips, less HP requirement.
/ Tiller or disc #11
This.
I want to eventually get a good disk to pull off the drawbar of my new tractor. The little 3ph disk we have now you could likely pull with an 8N.
/ Tiller or disc #12
A Hay King Pasture Renovator has been on my Want List for some time.
Please clarify your post.
Do you still use the Hay King first for deep slicing, followed by the roto-tiller, then the Spike Tooth Harrow? Or have you eliminated the Hay King?
Do you use the Spike Tooth Harrow for pasture renovation as a stand-alone implement at times?
Thank you.
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2017 Hyundai Elantra Sedan (A61574)
2017 Hyundai...
207270 (A52708)
207270 (A52708)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
