Chains Bucket hooks
   / Bucket hooks #21
My CK 2610 loader bucket is boxed across the top edge. This seems to make using bolt on chain hooks improbable. What type of set up is best suited to these buckets? Thanks!
Are you certain? Mine has a space right be hind the boxed in "tube". Its the standard 60" Kioti supplied bucket. Just enough room existed to drill through a single metal into a very stable spot lined up nicely lined up on each lift arm. And furthest back on the bucket edge I would think preferable anyway. The strongest point in the bucket is the area that the lift arm attaches. And by putting one on each side you get an even lift right straight on the arms. Both sides.
You have to measure correctly but there was enough space for both bolts, nuts and washers. The hooks I got from amazon have the holes for bolting on each side (link attached for source). Not front to back. You have to be very precise in order to be able to get the big thick washers to center as there is just enough space with little to spare. You only have I'd estimate 1/4" of play room. If not you'll likely have to grind or trim a washer. I measured these all out on tape applied to the top and spent a bit of time laying the holes out.
These are mounted right behind the boxed area in about a 3" space that is only one single thickness. Works perfectly with this style of hooks.
Link to amazon source for hooks: Amazon.com: Set of (3) Titan 5/16 Bolt-On Grab Hooks: Home Improvement
   / Bucket hooks #22
I see you used locking nuts. It appears the locking mechanism that keeps it form getting loose is plastic rather than a lock washer and regular metal nut. . Do you suppose that could reduce its strength?
No, the grade nut (it's strength) is not affected by the nylon locking feature.
Lock washers aren't locking. They actually make it worse. I haven't used them in decades. Down near the bottom: BillaVista.com-Nuts Bolts and Fasteners Tech Article by BillaVista
   / Bucket hooks #23
I have a post where I welded c-channel across top of bucket then welded chain hook to middle of c-channel. I’d never put a hook straight on top of bucket without c-channel. Certain to bend top of bucket.
   / Bucket hooks #24
Joel, is your C-channel the width of the bucket? Any pics with that post, and could you share a link to it on TBN? It might be tough to find otherwise.
Yours is a good idea, although probably not practical for most owners. Thinking more about this, 5/16" welded grab hooks with reinforcing plates would be an easy, inexpensive item for manufacturers to install standard on buckets, so I'm guessing there are other reasons they don't. Maybe concern about creating an invitation to misuse. :scratchchin: Even if adequately reinforced to minimize deforming the bucket, improper use can damage loader wrist pins and even cylinders.
   / Bucket hooks #25
I too welded a piece of C channel across the top of my bucket, then welded my hooks to that.
   / Bucket hooks #26
Those are commonly called "NyLocks", and graded properly (we only use high quality Grade #8 hardware) are just a s strong as any other Grade 8 nut.
   / Bucket hooks #27
You can buy very inexpensive forged hooks on eBay and weld them on to the backside of your bucket. I installed a set of 5/16 and 3/8's hooks on my tractor bucket. The 5/16 hooks are for 1/4" chains.
Jim, we sell a full line of weldable products too. We even have laser cut backing plates if needed:
Ken's Bolt on Grab Hooks <<Weld-On>>
   / Bucket hooks #28
I bought mine on Amazon , they are bolt on . I just drilled all the way through and bought bolts long enough at the local hardware store. My dealer welds theirs on.
I added bolt-on hooks to mine recently. On my bucket, there was a small space just behind that double walled lip. I drilled in that area and they bolted right on. Bought mine on Amazon. They came in a package of 3 and seem to be decent quality.
Link to amazon source for hooks: ...
Caveat emptor, from our FAQ page:
Q: Do you sell your Bolt-On Hooks or other products on Amazon or eBay?
A #1: No. Our products are only available through the Ken's Bolt on Grab Hooks <<Home>> website. Any "Bolt-On" hooks you see on Amazon or eBay are cheap (and imported from CHINA) copies of our products. The ones we have seen also came with cheaper Grade 5 hardware, and showed signs of very poor weld quality. They are also physically larger than our, and have not bee proof tested. These inferior parts are not compatible with ours.
A #2: Some exclusive brick and mortar tractor dealers do sell our genuine products. This is a very small list and they are always packaged with our name on the instructions.
   / Bucket hooks #30
I just went to TSC and bought a set and they work great.
   / Bucket hooks #31
Good info. Can you post up the comparison chart for yield strength between the Amazon hooks and your hooks? That would be very helpful info when comparing hooks.
Thanks.
Mike
   / Bucket hooks #33
   / Bucket hooks #34
Would seem like testing a few of the knock-off products to prove yours are stronger, better, whatever, would be a good marketing move. Otherwise, it's just speculation without solid proof that the claims are actually factual.
I get it though. It takes time and money to do this.
   / Bucket hooks #35
Here's the post with my bucket hook install. I've had it for years now and has been one of the most useful attachments I have.
My logic for the method is as follows:
1) I did not want to bend the top of my bucket like so many have.
2) I wanted to strengthen my bucket, which is why I'd never drill a hole in the top edge of my bucket. Also why I installed cutting edge at bottom as well as c-channel at the top.
3) I went with middle of bucket as I wanted no twisting force on my bucket and loader arms.
4) I went with weld-on as it will never come off for any reason based on my type of use of the machine.
After almost 10 years of use I have no regrets and my bucket remains dead straight.
Joel
Hope some find helpful.
https://www.tractorbynet.com/forums/welding/116067-looking-welding-advice.html#post1337783
   / Bucket hooks #36
Then there’s always the possibility they out perform his.
   / Bucket hooks #38
Here is my take:
I’ve been making/selling these since 2011 (the story is on the about us page), and we’ve had the testing info posted on the website since 2013. They started copying my main product just last year, so why should I have to prove mine are better?
How many negative threads/posts can you find on TBN about Titan products related to quality, fitment and customer service issues? And how many negative ones about ours? I’m a tractor guy just like you all, I’ve been a contributing member of TBN for a LONG time, and now I pay to advertise my products both to make money (obviously) but also to help support TBN. Titan is a “distributor” and they are not tractor people.
Sorry to the OP for the de-rail.
   / Bucket hooks #40
I added some reinforcement on both my NH and Kioti loader before adding hooks. On the NH a 2" heavy walled pipe fit in the whole length of the bucket top and on the Kioti bucket I welded a full length angle iron on the top of the bucket before the hooks.
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
JCB 509-23TC TOOL CARRIER TELESCOPIC FORKLIFT (A60429)
JCB 509-23TC TOOL...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
