Is this a suspension issue worth worrying about?
   / Is this a suspension issue worth worrying about?
I'm not worried about the engineering. Looks like standard slipper springs to me. What I'm wondering about specifically is the little pucker over where the springs come out the back. I'm assuming the hole in the tinner backer plate was a hair smaller or not quite lined up with where the springs come through.
   / Is this a suspension issue worth worrying about? #12
A lot of the bigger over the road trailers that I inspect on the job and even some of the trucks, have rubber pads up inside that the tale of the spring ride on which would prevent the slight damage you are seeing.
   / Is this a suspension issue worth worrying about? #13
If you have any doubt and since it’s a newish trailer under warranty take it back and get them to look at it just in case. Then the important part. Get them to write it down on a company letter head. If it’s needed later their will be way less debate about warrant issue even if the warranty is expired.
I suspect it’s fine.
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A49461)
2017 Ford F-350...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
Caterpillar Front Glass (A50854)
Caterpillar Front...
2011 New Holland B95B Cab MFWD Loader Backhoe (A51039)
2011 New Holland...
