? About landscape rakes
/ ? About landscape rakes #1
AlbertC
Perry, GA
New holland 3930
I have been wanting a landscape rake for a while and am looking at the EA extreme duty rake. Am having trouble deciding which one to get. I have a new holland 3930 which is about. 6 ft wide at the rear tires. I think a 6 ft rake is too narrow so I am considering a 7 or 8 ft rake.
I will use the rake primarily for raking up limbs as I have a lot of trees on my property and they are always dropping limbs and will also probably use it for smoothing out some ground that I am having cleared. Any ideas as to which size rake would be better.
Thanks
/ ? About landscape rakes #2
I got one purposely no wider than my tractor as anything wider was going to be too wide for the trails in my forested property. Can't say I have wanted a longer one ever.
Rear blade it a different story, wider is better for my use.
/ ? About landscape rakes #3
If you are staying with a manual adjust rake, then I would go with this one. Pay the extra to get it to be able to offset and get an 8 foot width. Put that 8 feet at a 35* angle and it is only about 78" wide.
/ ? About landscape rakes #4
I went with this same setup, worked out really nice. IMG_3134.JPGIMG_3159.JPG
/ ? About landscape rakes #5
As the owner of a manualy adjusted landscape rake I can attest to a fairly long learning curve what with angle of attack, depth, tilt, and angle of rotation. Gage wheels certainly help with the results (grading lawns), but that is another adjustment to keep track of. I bought a rake wide enough to cover my tracks rationalizing that fewer passes meant less compaction.
In shopping I noted that York Rake gage wheels are too close to caster or swivel in reverse. On my Land Pride the gage wheel brackets would have to be removed to rotate the tines, but they are far enough back to allow them to swivel when moving backwards. Also, since the gage wheels are further out (longer wheelbase), the results are smoother.
To Einthewoods' point, I have a tooth bar or poor man's grapple on my bucket that I use in the woods where the trail is as narrow as the tractor.
Excuse my ignorance but I did not see anything in the ad from EA about paying extra to get it to offset. This is the rake that I was thinking about getting but confused about the offset comment. Also,can you tell me why the offset feature is desirable? As you can see I have a lot to lear about using a rake.
Thanks
/ ? About landscape rakes #7
Thanks
You have to ask for that feature and they will do it for an additional fee. Just like countrybumpkin posted pictures of in post #4.
You will find that with a rake or rear blade, the offset feature allows you to get closer to areas that you may not be able to reach easily or even reach at all with the implement squarely behind the tractor. But get it off to the side some and a lot of things change. :thumbsup:
Some people feel that it is well worth the additional cost to have the extra capabilities. Some do not.
/ ? About landscape rakes #8
Offset for that rake is not listed on the website, if you call and order it you can request the option, think it was around 350 more.
/ ? About landscape rakes #9
Definitely get an 8ft with offset and gauge wheels.
/ ? About landscape rakes #10
I will use the rake primarily for raking up limbs as I have a lot of trees on my property. I will also probably use it for smoothing out some ground that I am having cleared. Any ideas as to which size rake would be better.
I have an ETA Landscape Rake with gauge wheels.
I have a Ratchet Rake bucket attachment.
For the two uses you have specified a Ratchet Rake will perform better for you.
You cannot see the Ratchet Rake in Photo #2 but it is on the bucket.
Pushing brush is better than pulling brush. You have infinite collection space in front and line-of-sight is better.
VIDEO: ratchet rake grading - YouTube
WEB SITE: Ratchet Rake, LLC - Tractor attachment, Bucket attachment, Loader, Skid loader, Kubota, Skid steer, Landscape rake, Brush remover, York Rake, Harley Rake, Rock Rake, Tractor rake attachment, Construction attachment, New Holland, Bobcat, Fire safety, Home fire safety, Fire prevention, John Deere, skid steer attachment, tractor implement
That would be great except that my tractor does not have a bucket.
/ ? About landscape rakes #12
Thanks
If you're buying this model then it IS the model with the offset. They have several different models.
Landscape Rake for Compact Tractors
/ ? About landscape rakes #13
When I bought mine, the dealer said to get one about 2' wider than the track (the width of the tractor wheels on the same axle) or slightly more. The idea was that when pulling the rake at it's maximum angle (the left/right tilt) you still want the rake wider than the tractor's track, with some margin for maneuvering and turning.
That being said, I went with a slightly smaller one (still longer than the track with the smallest angle set) since I was also pulling branches and deadfall out between trees. It does mean a couple more passes when I'm smoothing out some land I was working on, but that's OK.
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
58in Padfoot Vibratory Roller Skid Steer Attachment (A61572)
58in Padfoot...
