How to fix this road with ruts
   / How to fix this road with ruts
Back blades suck for road work. Your box blade with teeth is the right tool for the job. Get as much loos as you think you need then tip your box.
A back blade was the first thing i bought. Then i got a box blade and after 4 yrs of never putting the blade on again i sold it.
That is interesting. Which blade did you have and behind which tractor? was it all hydraulic?
airbiscuit:
Okay there is an argument of having a gauge wheel, or having skid shoes, which MtnViewRanch recommends over a gauge wheel...
   / How to fix this road with ruts #22
Skids are good too. You could always fab up your own gauge wheel (you can buy the wheel an d caster assembly for about $60 if you look around). Laminated Tire Assy w/fork, | Grizzly 8684
   / How to fix this road with ruts #23
IMO there is no need for "training wheels" if you have a hydraulic tilt cylinder...
Also, crowning a road usually means having to ditch both sides...which at some point may require a culvert...unless there is an issue of heavy ice build up and possible sliding...pitching the lane to a single side is the way to go to keep things simple and will make for less maintenance...i.e., only one ditch to maintain and it's easier to pull material from the low side to the high side in fewer passes without a crown to deal with...
Good luck...
   / How to fix this road with ruts #24
Garage wheels are nice.
When you go get the blade ask about wings to bolt onto the end of the blade. Turns it into a box blade almost. Their easy to remove although I seldom remove mine. By tipping the blade back it allows the gravel to go under and out from under the wings. Tiny bit of tilt back in with the top link and the gravel stays in the blade.
   / How to fix this road with ruts #25
Skid shoe, wheels —- both work.
Agreed; them’s that has all the proper hydraulics on the blade and are self opinioned real operators don’t need no training wheels. The rest of us ordinary folk that like a smooth shaped road have to use training wheels!
   / How to fix this road with ruts #26
I'm gonna disagree with just about everyone. From your picture, it looks like you have great drainage. Those giving advice for creating a crown must be thinking that your road is on some flat land. Since you are dealing with a significant slope, the crown isn't going to solve the problem. Same thing with tearing up the solid base that you already have. Once tore up, it will be VERY VERY HARD to get it solid again. This is probably the worse advice possible. There is no reason to go buy a new attachment to make changes to the road that do not need to be made.
First thing that has to be done is to identify the problem. Where your tires go over your road, they are removing material. Once removed, rain will remove more material.
The material that you are using to fill the ruts isn't the correct material.
You need to find larger, crushed road base rock. It needs to be a couple inches big so rain cannot move it. It needs to have jagged edges so that the smaller material will lock it all together. Crushed concrete works pretty good for this. And the big secret for it to hold together, and compact into a solid mass is water. It takes a lot of water to do this. A really good rain will do this, but it's tricky because right after the rain, everything will be squishy, but as the water dries up, the rock will lock together.
You need to remove all that lose dirt mixed with rock fill that you have put into your ditch. Probably just wait for it to wash away the next time it rains. Then start filling the ruts with the proper material and compacting it with your tires and as much water as you can come up with.
   / How to fix this road with ruts #27
The key to maintaining any road/lane with hills is to simply get storm water runoff to NOT RUN DOWN THE ROAD...it needs to run across the road...
Unless it's paved...every time it rains enough to create runoff it will erode and tend to create ruts...
The steeper the hill the more pitch (or crown) is required to prevent accumulation and washes etc...
   / How to fix this road with ruts #28
A little video on road maintenance with a grader. Explains how the blade is used for proper results.
   / How to fix this road with ruts #29
I don't think you've said whether this is a road used daily by cars and trucks or something used less frequently and perhaps by more trucks and equipment than cars. I don't see any gravel, just dirt. I also see it is California, so perhaps very dry most of the time, but possibly extremely wet in winter. In any case, previous posters who emphasize keeping the water from running down the road are right. Assuming somebody uses the road with some frequency, one of the cheapest tools you might want to have on hand is a shovel. Keep it in the back of your vehicle and get out and do something about water running down the road when it rains. That helps minimize the water cutting the ruts deeper. If the road is infrequently used, another ploy is to install "water bars" which are just shallow ditches cut on a slight diagonal across the road to divert water off the road. These may be reinforced on the upper side by a piece of wood, usually a 4" or so diameter round cut from a tree, but a 4X4 will do. Wouldn't do for a driveway, but it's common practice here for logging roads and such. The final thing is, once you get the road in shape, don't let it get too far out of shape, it's a lot easier to do minor repairs with whatever equipment you have than to have to do a major re-grading and ditching.
   / How to fix this road with ruts #30
If your bolting wings on a rear blade..you just made a box blade so buy one to begin with.
2005 Jeep Wrangler 4X4 SUV (A55758)
2005 Jeep Wrangler...
UNUSED FUTURE FT46 - 46" HYD MULCHER (A54757)
UNUSED FUTURE FT46...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
POLARIS RANGER 570 RTV (A51406)
POLARIS RANGER 570...
UNUSED GRASSROOTS IMPLEMENT 4' BOX BLADE (A54756)
UNUSED GRASSROOTS...
