Rotary Cutter New linings for slip clutch on Bush Hog SQ160?
   / New linings for slip clutch on Bush Hog SQ160? #1
fishrman
You wouldn't think it would be that big of deal to find the right linings and, maybe it isn't but I seem to be having difficulty. Not even sure I need to replace them but have a feeling, I didn't do them any good. I was mowing yesterday in Heavy weeds and grass. It started not sounding right and on my next pass I noticed the weeds and grass were more laying over than being cut. Dumb me, finally turn around to look and see smoke coming from the slip clutch area. I quickly disengaged the pto and headed to the house. It was still smoking 5 minutes later! I assume I burnt the linings bad enough that they will need replaced. It was hot enough that it melted the little plastic doors on either side of the plastic housing around the clutch. At any rate, in looking at the manual, it tells me there were possibly 3 different ones used on the SQ160. That's helpful! I have concluded that it is a EG/Comer with the bolt pattern that is 2 bolts close together and spaced in 4 positions around. It is NOT the one that is 8 bolts spaced evenly around, if that makes sense and, it is not the solid cast Bonioli&Pavesi/Binacchi. The manual tells me which spring length setting to use but doesn't say anything about which linings I need. I was hoping I could buy them and have them ready when I tore it apart but seems all the dealers want to know what size they are and I can't tell them because I haven't torn into it yet. Does anyone know which ones I need?? Thanks for the help!
   / New linings for slip clutch on Bush Hog SQ160? #2
Download the parts manual for the SQ142, SQ148, SQ160, SQ172, SQ184, SQ84T from Bush Hog HERE. It should help you.
Thanks! I think, I figured out it is the one made by Comer?? Not completely positive but believe that is the one. I may have to tear into it if I want to get an aftermarket one before the ones I just ordered from dealer get here. Told me it may be Tues. or Weds. of next week. Thanks for the link!
   / New linings for slip clutch on Bush Hog SQ160? #4
Sometimes it's best to tear something apart before trying to order parts. It's possible that one could resurface the hub faces and the disk and get it working again, but at any rate you have the disk and you can then measure to find an actual match (if it turns out that that's what's required).
I have no doubt that you are right. I finally got the pads but they failed to order the needed plastic shield that goes over the slip clutch and I felt with Grandkids around, I should replace that so I am currently waiting on that part to arrive before tearing it down. Stay tuned and thanks.
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
Metal Sunflower Lawn Art (A55853)
Metal Sunflower...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2022 Kubota Z422-54 Zero Turn Mower (A55314)
2022 Kubota...
