the old grind
Super Member
- Joined
- Jul 21, 2012
- Messages
- 5,308
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
If you pull injectors, at least bleed them THEN. If there's water in them, I'd worry about wear more than metal 'swelling' or 'shrinking' once heated to 'blue'. (past experience heat-treating alloy tool steels)
Both my CUTs (CNH/Shibaura) have o'flow lines to carry excess fuel back to pump. When servicing the fuel system I've found that they will not fully bleed injectors every time, so I do so manually. That said, bleeding a few oz/bubbles/water (yes, water sometimes) at just one restores smooth running.
Bleeding the pump supply will not for sure flush individual injector lines, and 'return' lines from them could have, by now, returned some water to tank that had stayed from the first shot of kero. :2cents::2cents:
