Chemical vs water fire extinguishers
   / Chemical vs water fire extinguishers #41
Having lost a car to a fire I now carry good fire extinguishers in all cars. I try and buy the non-corrosive types. The new Halon replacement ones like Halotron. I mean why save a vehicle just to have it crumble and deteriorate later on? Save it to restore or fix it. Might want to think about this angle too.
   / Chemical vs water fire extinguishers #42
Unfortunately near useless on a typical vehicle fire.
   / Chemical vs water fire extinguishers #43
For around the home, I would retain the standard ABC Dry chemical due to the effectiveness and cost of the units. In a car, I would either go with the Amerex Halotron1 or the Ansul Cleanguard. No mess with either and they are both highly effective. Cost is about double what a dry chemical is but it pays for itself if you need to use it. Dry chemical WILL destroy most electronics it touches as it is highly corrosive to circuitry. Having set one off in a car once before I can attest to the fact that it is almost impossible to get all of the residue out of the car, no matter how much you vacuum it.
CLUB CAR (A55758)
CLUB CAR (A55758)
2013 Freightliner 122SD Day Cab Truck, VIN # 1FUJGNDR7DDBZ7653 (A54865)
2013 Freightliner...
White Metal Roof Panels (A55758)
White Metal Roof...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A56129)
2021 MACK GRANITE...
Mercury 60hp Boat Motor (A54865)
Mercury 60hp Boat...
