Comparison I've got it narrowed down but i still have questions.
   / I've got it narrowed down but i still have questions. #1
mfsr
None
Hello all, I've been silently stalking the forums for the last few months absorbing everything I can. The site is great and I really appreciate all the knowledge you all so willingly share.
I'm finally getting close to pulling the trigger on my first and possibly last tractor. I have 2.25 acres that is level and heavily treed(mostly smaller lodgepole). I will eventually have around 400' of gravel driveway plus 2 big circular drives for the house and shop.(The property is long and skinny). I dont intend to have any wide open mowable areas as I am keeping as many trees as possible. The tractor will be used for digging up smaller stumps, grading my driveway, clearing brush, smoothing the open areas, blowing snow and most importantly, having fun. I intend on getting a FEL, BH, front mount snow blower, box blade and maybe a small tiller.
While it is level, the terrain is rough so ground clearance is a concern. Because of that i have shifted my focus from the bx and 1 family tractors to the B and 2 family. This along with price, size restrictions, dealer proximity, dealer comfort, and brand comfort has led me to 3 tractors. The 2018 JD 2025R, and the 2018 Kubota B2301 and B2601.
I've gathered up the most current specs i can find and have attached them. On paper, the 2025 is closer to a BX than the B01 series. It really isnt much of a comparison.
I've heard pros and cons for both plastic and metal hoods so i am sixes on that. I'm not a big guy so the operator platform on every tractor i have sat in is fine with me. It's my first tractor so i dont have an affinity for the treadle or the twin touch. I dont even have a favorite color. I'm a clean slate.
The 2025R is a little heavier. I know i am going to give up some FEL capacity with the addition of a 54" quick attach bucket and QA coupler. The alternator upgrade for the B01 is a cheap add-on so that is kind of a wash.
First of all, am i looking at all the numbers i need to look at? Is there something i am missing?
Secondly, despite all the red on the 2025R, the one item that bugs me the most is the 'rated engine speed'. 3200rpm seems really high especially when you are only getting 2100rpm out of the mid pto. The one thing i really want this tractor to do well is blow snow and 2500rpm at 2800rpm engine speed seems like it would throw alot better and more comfortably than 2100rpm at 3200rpm engine speed. Am I incorrect?
I'm sure i'll have additional questions as i get closer.
Thanks in advance.
   / I've got it narrowed down but i still have questions. #2
Have you thought about the 2032r? You get more PTO hp and 2500 rpm rated engine speed.
   / I've got it narrowed down but i still have questions. #3
I love John Deere's 2R series and the 2032R would have better specs than the 2025R which is really a tween tractor between the 1 series and the larger motor 2R series. There is a major downfall with the 2R and that is clearance at the drawbar: 9.8" clearance at the front and only 6.5" at the rear drawbar. mfsr, what about pushing up to a B2650? You get a 14.6" ground clearance and your width goes from 49" to 53.7" plus you can have wheel spacers installed which should give you about another 3-1/4" extra width for stability. Plus you get another 264 lbs of weight.
The 2032r has been at the top of my list since I came to the conclusion the the Scuts wouldnt cut it. Unfortunately, the 32 hp comes at a bit of a premium and is a tad out of my price range. The 2301 is my sweet spot and a got a quote on a 2025r that was about the same. The 2601 uses the same FEL, BH, etc as the 2301 so you only a little more for the base tractor. The 2650 is just a little jump in price for the base tractor but uses bigger FEL, BH, etc so it kind of steam rolls from there. Admittedly, my budget is flexible but the boss is likely to shut me down at some point..
I just felt like I was missing something on the 2025r. it really doesn’t stack up and is more of a 1 family tractor on swol. I really like the dealer I worked with and I wanted to make sure I gave him a fair shake in my evaluation. I do like the flip seat on the 2025 BH though.
   / I've got it narrowed down but i still have questions. #5
https://www.pefleys.com/inventory/?...ubota-b2650hsd?dlr=1&pcid=3010906&sfc=0&ssc=0 <-- B2650 w/loader $19,100
https://www.pefleys.com/inventory/?...ubota-b2601hsd?dlr=1&pcid=3010906&sfc=0&ssc=0 <-- B2601 w/loader they ain't saying.
https://www.pefleys.com/inventory/?...ubota-b2301hsd?dlr=1&pcid=3010906&sfc=0&ssc=0 <-- B2301 w/loader $17,100
These are prices from the same exact dealer (didn't check to see how good or bad their prices are but they work for this example). Looks like the 01 series takes a BH70 (list price $7149) and the 50 series takes a BH77 (list price $7783) backhoe. I was thinking they took same backhoe but did a double take on Kubota website before posting. The snow blower, box blade and tiller should be the same price for either tractor (you might be able to get bigger snowblower but let's assume you use the same size.)
So....let's guesstimate the B2601 would run $18,100 at this dealer - that would make the upgrade to the B2650 a price jump of $1k for the tractor and just over $500 for the backhoe. If you get the snowblower and the other accessories all up front then you are over $30k for the whole package. If you are financing at 0% for 60 months your increase in payment for the upgrade will be roughly $28 a month, 0% for 84 months will be roughly $16 a month (You have to put 20% cash down to get 0% for 84 months - I accounted for that but your overall payment would be less because of the downpayment). If you pay cash that's extra out of your pocket. If you are financing then not big difference.
   / I've got it narrowed down but i still have questions. #6
I’m not sure what your asking on PTO speed? The listed RPM is what the shaft is turning not what the engine is turning. I assume the manufacturer gears everything to match that PTO speed well.
   / I've got it narrowed down but i still have questions. #7
mfsr - - Welcome to TBN and the forum. By the way - update your profile and let us know where you are located.
Suggestion - - take a look at what you plan on doing with your new tractor for the next five years. What percentage of the workload/projects will require the use of a back hoe.
Now look at the cost of the back hoe as compared to the overall cost of the tractor - how to the two percentages match up( workload % vs back hoe cost %).
Back hoe attachments are very expensive and often represent only a very small percentage of the overall workload but a high percentage of the total cost of the new tractor package.
Many feel a back hoe is very essential when in actuality it is a very small percentage of the expected use. Very adequate back hoe equipment can be rented for those specific situations and can save considerable money and a lot of wear and tear on your equipment.
Just a though for you to consider.
   / I've got it narrowed down but i still have questions. #8
How much would it cost to have a backhoe delivered to ones house and include 3 days of rental time, then be picked up by the company that you rent it from?
   / I've got it narrowed down but i still have questions. #9
That is EXACTLY the situation/costs that mfsr should be considering, Randy. I not saying - "don't buy a backhoe attachment". What I want mfsr to understand is if he only has a couple short projects for a backhoe over a longer period of time - - it could be a lot more economical to rent equipment. The backhoe makes a pretty expensive ballast attachment on any tractor.
If you are in a remote location - such as I am - everything from lumber, concrete, rental equipment, contracted services - is expensive.
Thank you for emphasizing my point.
   / I've got it narrowed down but i still have questions. #10
<snip>
This is true on the backhoe, especially a small one. However one of the main things us certified old farts need to consider is our backs. I've had 3 back surgeries. I plan to use my backhoe for many little things that I normally would just have "muscled through" when I was younger.
For me a 9.5K mini-ex would cost about $330 for 1 day ($940/week) and a 4 hour delivery/return (don't know cost on that). And then there is the consideration - will it be available WHEN I want it. What if the weather is bad?
But back to the OP -
Have you considered the L2501? Right now that seems the sweet spot for SCUT in the Kubota line, basically slightly detuned for EPA limits.
2007 Anderson 25ft 7 Ton T/A Flatbed Equipment Trailer (A55852)
2007 Anderson 25ft...
DIRT DOG MPG72 72" MUD PLUGGER (A57192)
DIRT DOG MPG72 72"...
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
UNUSED FUTURE FT1000T VIBRATORY ROAD ROLLER (A57192)
UNUSED FUTURE...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A56858)
2006 International...
