Troy Bilt vs Cub Cadet XT1
/ Troy Bilt vs Cub Cadet XT1 #1
Ledgemere Farm
Limerick, Maine
A bunch
I don稚 see many differences between the Troy bilt super bronco and the Cub xt1. What痴 the advantage of one over the other
/ Troy Bilt vs Cub Cadet XT1 #2
Well, they both are MTD products. You may want to be specific on the models as I think both are available with different decks.
/ Troy Bilt vs Cub Cadet XT1 #3
Normally you pay more for the Cub Cadet name for the same product.
/ Troy Bilt vs Cub Cadet XT1 #4
Which color do you like better?
/ Troy Bilt vs Cub Cadet XT1 #5
Going through the same thing. It appears that the only difference is the hood design and color. Wish me luck... I'll go with the Troybilt Super Bronco.
/ Troy Bilt vs Cub Cadet XT1 #6
Used it for the first time yesterday and was impressed how quickly I did my yard. From a 42 to 50 makes a big difference... got done in about half the time!!
/ Troy Bilt vs Cub Cadet XT1 #7
Good choice glad your happy. Cub Cadet in my opinion is nothing more than a name brand of yellow and black. They force people into the impression of having to use cub cadets own brands of expensive fluids and parts or destruction of the machine and warranty void will happen. No difference if its a rider, weed whacker or a compact tractor chances are that some other company made the basic product and Cub Cadet put there colors on it. They do have great customer service at the company level I can say over the others and is an important factor for some like me. Bottom line would be if you want the extra expense for the company support over the product or do you feel comfortable with who you purchased it from to stand behind it.
/ Troy Bilt vs Cub Cadet XT1 #8
Hopefully Troy bilt has a similar CS department if I ever need it.
/ Troy Bilt vs Cub Cadet XT1 #9
I bought a Troy Bilt 50” mower 5 yrs ago as I wanted the Koehler Courage motor. I have been quite pleased with it and would buy it again.
/ Troy Bilt vs Cub Cadet XT1 #10
Nice ... the engine in the one I got is a Koehler but not the Courage. I did use it a second time , this time with a bagger in wet grass. Much to my surprise it performed unbelievably! It cuts my mowing time by 1/3! It does make a mess flushing the deck with water , but that's to be expected. I'm very pleased with my purchase. I
I'll keep posting as time goes on.
/ Troy Bilt vs Cub Cadet XT1 #11
I find none of the deck rinse ports works worth a darn, leaving as much grass remaining as it removes. I drive my mower up a set of inclined ramps so I can get underneath with the pressure washer and that works well. As long as I rinse the deck well there is zero corrosion. I coat the underside well with fluidfilm each fall before the winter and this mower should last many years.
/ Troy Bilt vs Cub Cadet XT1 #12
I never checked how well the ports worked. I'll give it a look next time I get ready to use it. Alot of debris did come loose after flushing it.
/ Troy Bilt vs Cub Cadet XT1 #13
Flush? What is this Flush of which you speak? Old Craftsman 19.5hp, 42" deck rider that is about 25 years old. It gets rode hard and put away wet. I do scrape the underside of the deck whenever the blades need sharpening or replacement. Deck is still solid.
/ Troy Bilt vs Cub Cadet XT1 #14
Many of todays decks have a port or ports to hook up a quick connect to a hose to flush debris out from the underside of the deck. https://i.ytimg.com/vi/_8ef5QOcLjA/hqdefault.jpg
/ Troy Bilt vs Cub Cadet XT1 #15
I guess a flush port would be a good thing if it works and cleans really well. Not so good, if made of cheap plastic and will be broken and useless in a year or two.
/ Troy Bilt vs Cub Cadet XT1 #16
I bought a Troy Bilt Mustang with a 50 inch deck and a Koehler motor in 2008 and it is still running fine. Other than replacing a blade spindle, the routine maintenace items and the battery 3 times I did not replace any other parts. It is starting to leak a little oil but not much. Every time I cut grass I cut 5 acres. I do the regular maintenance and scrape and paint the deck at the end of each season. Not knowing how much longer it would last I bought another Mustang 2 years ago. I use it occassionally but very little.
/ Troy Bilt vs Cub Cadet XT1 #17
Deck flush ports BLOW. They blow the grease out of the spindles and cause them to fail. Totally worthless accessory. If you use them, better be greasing your spindles right after you 'wash the deck' or your spindles will fail prematurely.
