Smaller tractor and EA 850lb aerator?
   / Smaller tractor and EA 850lb aerator? #1
Jeff59Va
Member
Centreville, VA
Kubota L3240HST, Kubota RTV1120D, Kubota BX2380
I have the Everything Attachments heavy duty 48 inch core aerator. Weighs 850 pounds per EA. Used it a couple times now with my Kubota L3240 and it works great. The L3240 has a loader and loaded rears with R4 tires, so it is a bit hard on the turf for aerating, particularly if I do it when the soil is moist.
I'm considering getting a smaller tractor with turf tires and a belly mower for other reasons, so I would like to get one to handle the aerator too if possible. Does anyone have this aerator (or a similar one) and are you using it with a smaller tractor? Seems like a B-series Kubota or a John Deere 2320 would handle it fine, but what about the small tractors like a Kubota BX or a John Deere 2305 could these smaller tractors handle an implement that big?
I have looked at the Tractor Data charts for 3 point hitch lift capacity: for example, JD 2305: 1450 lbs. lift, 681 lbs. at 24 inches. Just not sure where that aerator falls in terms of how far out from the ends it would be.
   / Smaller tractor and EA 850lb aerator? #2
Generally speaking, Lower Link spread width on subcompact tractors is 19" Subcompact Lower Links may not spread wide enough to fit aerator draw pins.
Lower Link spread width on Cat 1 Three Point Hitch compact tractors is 26".
RESEARCH BEFORE YOU PURCHASE.
   / Smaller tractor and EA 850lb aerator? #3
I have the 36" EA aerator and have run it on a BX1500 equipped with a belly mower. It will pull it and lift it, but its really too heavy for the tractor. In particular additional front weight is needed. Everything is a lot better when I use it on our B9200.
   / Smaller tractor and EA 850lb aerator? #4
I know this is an old thread,…but what route did you end up going with? I’m considering a 48 inch to be used with a Bobcat CT122. I’m not worried about pulling or lifting it. I’m a little concerned with the weight when lifted on the turf, because I have unloaded R4 tires as well.
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
2024 Schulte 5026 Batwing Rotary Cutter (A55315)
2024 Schulte 5026...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2022 Horizon Trailer (A55973)
2022 Horizon...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
