Miami pedestrian bridge collapse
Status
Not open for further replies.
/ Miami pedestrian bridge collapse #141
I like watching people respond to one.
An example is the hype surrounding the upcoming meeting between N Korea and us. :)
/ Miami pedestrian bridge collapse #143
We shall see.
There's an update over on Welding Web, posted by Tigatoo.
His comments are based on
FIU bridge collapse update: Photos show severe cracks | Miami Herald
Here's one of the photos in it.
HWY18MH009-investigative-update_Page_5_Image_0001
/ Miami pedestrian bridge collapse #146
AFAIK, all these pics were taken before the bridge collapse.
HWY18MH009-investigative-update_Page_4_Image_0001
HWY18MH009-investigative-update_Page_5_Image_0002
/ Miami pedestrian bridge collapse #147
By the looks of those cracks it appears the bridge was starting to move a few days before it went down, I find it hard to belive that they didn't close that road after seeing that.
Hey, Cali,,, the way you linked it, you gotta be a weldingweb member to view it,,, :confused:
Oops, sorry. Last night a link to Miami Herald's photo returned nothing so I substituted Tigatoo's downloaded copy of it. Maybe I didn't wait long enough. Today the link works so I updated the post above. The photo is the final one in the Miami Herald article.
Looks to me that the measuring stick probing 6 inches into the 'crack' illustrates separation of Diagonal #11 from its attachment point.
/ Miami pedestrian bridge collapse #149
That would take a bit of poly filler.
When will the investigation make its results known?
I wonder if the "TRUTH" will ever come out?
/ Miami pedestrian bridge collapse #150
You'll have to define "truth." If you meaning blaming someone - no. The NTSB is conducting the investigation. They are precluded by Congress from issuing reports that include finding fault or blaming someone as Congress does not want the agency acting as an expert witness and/or testifying in court. They will only document the mechanisms that caused the failure. That could include: design, materials, construction methods, etc.
The NTSB is a totally independent agency. They are not part of any other federal department so they do not answer to appointed heads of departments. While most people are familiar with the NTSB's role in investigating aviation accidents, they have a number of different offices (divisions) dedicated to investigating accidents associated with: railroads, pipelines, hazardous materials; aviation safety; highway safety; marine safety.
They have investigated hundreds of bridge failures and accidents - you can find the reports on their website. There is no other investigative agency that can perform the investigation to the level of the NTSB, because if required, they will build replicas of the portion of the bridge that failed and test the replica for structural performance.
/ Miami pedestrian bridge collapse #151
So the whole thing is likely to be repeated (with blame this time) within the course of civil suits.
/ Miami pedestrian bridge collapse #153
If I was a worker and saw those cracks....I would have got the he77 off that bridge and stayed away. It is only common sense that those cracks were a sign of some MAJOR movement.
/ Miami pedestrian bridge collapse #155
My bet is that they were tensioning that member, and they should have been detensioning it. Engineering systems use a safety margin of 3. One has to seriously make a mistake for a calculation to be off by 3. Post tensioning systems could easily have overstressed that concrete joint.
Adding tension to the member for transport, and detensioning it later makes sense. Adding tension after it is in place does not. If they were attempting to "close the crack" by tensioning that member, the person in charge should not have been.
/ Miami pedestrian bridge collapse #156
Way beyond the news cycle. Collapse, what?
/ Miami pedestrian bridge collapse #158
People seem to prefer their disasters fresh!
Status
Rhino SE8 Rotary Cutter (A64047)
Rhino SE8 Rotary...
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
2019 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
CUB CADET WST100-22" WHEELED STRING TRIMMER MOWER (A63745)
CUB CADET...
2023 Boxer 700HDX Compact Skid Steer (A63116)
2023 Boxer 700HDX...
300 GALLON 3PT SPRAYER (A63290)
300 GALLON 3PT...
