Lift Arm leveling box for 3200
   / Lift Arm leveling box for 3200 #1
widefat
Central Va
Kubota L3200 Husq GT52XLS Husqvarna LC121P Husq 455 Rancher Stihl FS90 Stihl MS170 99 Ram 1500
I searched the forum but did not find an answer, and have not found anything online yet.
Seems odd - I cant be the only person to want to do this.
Anyway....
I would like to replace the stock adjustable lift arm on my L3200 with a crank lift box leveler.
I have found several online, but none specifically listed as compatible.
Unless someone here has done it, I suppose my next step is to get off my lazy bum and measure/search specs to find a good fit. Or maybe call Messicks. Or take out a loan and visit my Kubota dealer.
Sources?
TIA~!
   / Lift Arm leveling box for 3200 #2
Oh I wish they did and Ive search many times in the past but cant find one that I believe would fit without modifications.
Before I switched to Kubota I had Fords in the past and I miss that crank lift arm assy.
I did however order a new tractor L2501 over two weeks ago (yet to be delivered) and I added the deluxe RH lift arm that I believe comes standard with the larger tractors L-Grand series.
Its not a crank but its design is more desirable for me. They cost around 200.00 to 250.00
Good luck I hope you find something that will work.
You cant see it very good here but it has a square stock that you slide up, then turn, and then lower back down on two guide pins.
Screenshot: ⁨untitled - l6.pdf
   / Lift Arm leveling box for 3200 #3
I don’t like the Grand L box style adjuster. My previous L3410 came with the crank style, which I prefer. FYI, the Kubota crank style (assuming it would fit) is prohibitively expensive OEM. When I looked a couple of years ago the parts required were in the $700.00 ballpark.
   / Lift Arm leveling box for 3200 #5
Anyway....
Sources?
TIA~!
Being a Ford owner, I cannot offer any recommendation for a Kubota.
I replaced the crank style leveling box on my Ford 1920 with an aftermarket unit.
I measured the old leveler, and shopped for a generic replacement.
Found one, and it works great.
Seems as though you might be able to do the same, but perhaps with some modification.
   / Lift Arm leveling box for 3200 #6
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
FIMCO 60 GALLON SPRAYER (A52708)
FIMCO 60 GALLON...
Dewalt D28755 14" Cut-Off Machine (A59076)
Dewalt D28755 14"...
2010 International 7600 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2010 International...
2020 Chevrolet Tahoe SUV (A55973)
2020 Chevrolet...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
