PTO shaft cover/shield question
   / PTO shaft cover/shield question #1
vidio1
Madisonville
Kubota B7610
So I bought a Bush hog the other day that's been sitting forever. One of the things I need to replace is the PTO shield. After a bit of research it seems it came with a #4 Binacchi driveline, Bush hog part #90012BH for the shield assembly. Problem is, it's about $90. Will any generic #4 shield work? Are the bearings brand specific? Does anyone have a favorite online store for stuff like this? I've checked Agristore, but they are out there. Thanks for any help.
   / PTO shaft cover/shield question #2
Where do you live?
Western Ky
   / PTO shaft cover/shield question #4
This is a great question as I'm in a similar situation with a sq72. Did you ever make anything work?
Thanks!
No, I ended up selling it as is.
   / PTO shaft cover/shield question #7
Yes - the entire two part PTO shields are NOT cheap. If you saw what it takes to mold them - you would understand why. Very little to do with the cost of the plastic - a whole lot to do with the cost of the molds and molding machinery.
   / PTO shaft cover/shield question #8
For series #4-48"-74"
Inner diameter of bearing on inner tube: 46 mm / 1 13/16 in.
Inner diameter of bearing on outer tube: 53 mm / 2 1/16 in.
These are available for less than $40.0
   / PTO shaft cover/shield question #9
Thanks, but by the time I saw your post I had already ordered one. Do you have an online Link for the shield in your post (for the next person who needs one)?
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
FRONTIER 5' BOX BLADE (A52708)
FRONTIER 5' BOX...
2015 FREIGHTLINER M2 26FT BOX TRUCK (A58017)
2015 FREIGHTLINER...
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
MAYTAG ATLANTIS WASHER & DRYER (A54757)
MAYTAG ATLANTIS...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
