Tundra Update
/ Tundra Update #1
deerefan
louisiana
1952 8N, 2005 JD 5103
I figured I would post an update as I turned 5 years of ownership with my 2013 Tundra. I have 127k miles on the 5.7. It has had only 2 issues-a faulty charcoal canister and broken passenger door lock actuator. I average 18.5 mpg, keeping my rpms at 2k or less (75 mph or less). The truck is as tight as the day I bought it. No squeaks, rattles or vibrations. It is going in the shop at the end of the month for a full fluids change and spark plugs as well as serpentine belt. It has held up better than the Fords and Chevys I previously owned, just seems more heavy duty. I plan to keep it until at least 250k and will more than likely get another. This is the first Toyota I have owned and overall am very pleased.
/ Tundra Update #2
Does that one run a timing belt or had they switched over to chain by then?
/ Tundra Update
It is a timing chain. Not a big fan of the belt.
/ Tundra Update #4
Six decades of Demming and Toyota is at the top.... not surprised. Kubota knocking on JD door....
/ Tundra Update #5
Our family are Toyota fans. Collectively, our family have owned more than 15 Toyotas. Other than routine maintenance, I recall only two problems out of all of these vehicles--an airco problem and a timing belt on a Cressida, long ago. We are now on our third Tundra and really like them. Reliable and solid, and like the OP said, tight, no squeaks or rattles, good smooth ride, etc.
/ Tundra Update
I like how I was able to get console shifter in the base upgrade model-cloth seats, all power, crew cab, bed liner and chrome tube steps and 18” alloy wheels. I tow occasionally and when we relocated our farm I pulled our (separately) 8N and JD 5103 w/ loaded tires and 6ft hd bush hog attached-I am estimating 8-8.5k lbs with trailer-very well. No gear hunting at all. The engine, 6spd and 4.30 gears work well together.
/ Tundra Update #7
Glad you are having luck;my buddy has one it has been a money pit;replaced everything but the motor and transmission.Motor has been out(to change the frame!).
/ Tundra Update
Wow. What year is it?
/ Tundra Update #9
/ Tundra Update #10
Toyota’s are so reliable I don’t believe your buddy.... no way...
/ Tundra Update
While I know you are being humorous, it has been the most reliable vehicle we have owned along with my wife’s 2013 Expedition. Both been to shop one time for minor issue. We bought the Expedition used early 2015, it tows well also, but not the peppiest vehicle.
/ Tundra Update #12
The frame issues were mainly related to the Gen1 Tundras, 2006 & older. I had a 2004 Sequoia (SUV version of the Tundra) and it was reviewed by the dealer for potential frame rust. No severe rust was found but they applied an undercoating on their dime. If it would have shown signs of heavy frame rust, Toyota would have replaced the frame on their dime.
We've had several Toyotas, including 3 Tundras. (Currently have a 2011 with 102k miles). Awesome trucks. Use it to tow our 8500# camper, which it does very well. (Rear looks loaded down in the pic with the camper, that's just a dip in the driveway...). I really couldn't ask for more out of a 1/2 ton truck.
/ Tundra Update #13
I have a 2000 Tundra that I've worked hard and put up wet on a regular basis. I've towed at it's limits (weight distribution limits) countless times. The frame (made by Dana Corp) was replaced but that's the only non routine work it's needed. It's over 200k miles on it and doesn't burn a drop of oil and the transmission is as strong today as the day it came off the factory line. Every day I look at it I tell myself I should upgrade but I just can't justify it since it's been paid off for more than a decade and everything works as it should. I can't say how good newer trucks are but I've had a 94 Dodge with a 318 that blew the transmission pulling a small trailer with two dirt bikes on it. Was under warranty but after it was fixed I moved on to a used F150 but it just didn't grow on me. The transmission seam to like to shift between gears right at 50 mph so going down the highway it was always shifting up and down. Had a GMC before the Dodge which was a good truck but seam to always need small things. I probably would of bought another f150 after the Tundra but it's been so good I'd only buy another now.
/ Tundra Update #14
View attachment 566084View attachment 566085View attachment 566086
I had a 2004 Tundra and the frame had rusted badly enough I decided to trade it in. I don't believe it ever got a recall for the frame though.
/ Tundra Update #15
You missed out... Could have received a new full frame/mounts/etc. There was a date range that you had to satisfy to have it inspected. I don't recall the date time frame at this point.
/ Tundra Update #16
I’m a Toyota guy....have a 1980 FJ40 Land Crusier and a 2016 Avalon. The Tundras are good trucks but it seems like they’ve been building basically the same truck for a decade now. Time for Toyota to update it.
/ Tundra Update
I do agree, would like to see a more powerful drivetrain, diesel option too. On the other hand, why fix what’s working? Kind of torn here.
/ Tundra Update #18
Not to rain on your parade but all manufacturers have great stories of reliability. Years ago I went to Disneyworld and sat behind the shuttle driver. I was nosey and looked at his odometer. It was reaing 850K. I said how the heck did you get 850K out of this thing (it was a chevy van). He said all his vans have 800K of more on them, Ford, Dodge, Chevy, Gmc. He said they all run 24hrs a day 7 days a week only shut off for fuel, and regular service. That trip taught me a lot.
I've been driving for 50 years and owned dozens of brands and have only had brand that I considered a problem and that was a Mercedes Sprinter. Otherwise all served me well with zero problems. One Ford prodcut I sued the dealership for a replacement because of body damage they hid from me on a new vehicle. I was confident I was going to win so I never spent a dime on service on the vehicle. The case drew out for three years and 60K miles before they settled by giving me a new replacement. I only changed teh oil once. I necer had a bit of problem with it. We just traded the wifes Jeep Commander after 10 years and 180K miles and only replaced battery, shocks,oil changes, tires, etc. other than that it ran like a new car when we traded it. Never let us down once. I did 300K on a GMC van I used for business and that vehicle was beat by everyone that ever drove it and sold it to an employee who is still driving it.
Lastly look around craigslist people are selling vehicles with 150K-300K miles all day long, all brands.
Yes Toyotas are good, but so are a lot of other brands
/ Tundra Update #19
Another Toyota fan here. First was a 2003 Corolla. Bought it from my brother-in-law. It lived with Maine roads, winter salt and salt air from the ocean for 9 years and when I traded it in, it didn't have a speck of rust on it, including underneath and things like brake lines. Pretty darn impressive, especially after my 2006 GMC 2500HD had a bumper rust completely through in 5 years.
Traded the '03 on a '12 Corolla and the '06 GMC on a '13 Tundra.
The Tundra had the dreaded "cam tower oil leak" which Toyota fixed under warranty, upgraded me to a free Platinum service plan and provided me with a nice loaner while they fixed it. Otherwise, absolutely no issues whatever. Better fit and finish, much more comfortable interior, rides better, tows at least as well as bigger (3/4 and 1 ton) GM's I've owned.
Since I retired, I don't put a lot of miles on a vehicle (Tundra just turned over 40K after 5 years...) so I may never need a new truck. If I do, it'll be another Toyota.
/ Tundra Update #20
I知 a Toyota guy....have a 1980 FJ40 Land Crusier and a 2016 Avalon. The Tundras are good trucks but it seems like they致e been building basically the same truck for a decade now. Time for Toyota to update it.
No... no... that’s were problems crop up, improvements yes, but update for updates sake... no.... it’s being updated but places that need improvement to be more reliable..... not necessarily where you can see.... get it....
I drive the flagship. 200 series LC.
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
2012 Hyundai Sonata (A62679)
2012 Hyundai...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
