Ford 1900 coolant
/ Ford 1900 coolant #1
Oakley
Member
2002 Kubota BX2200
What coolant should I be using? It currently has green fluid in it and I need to top it off. Need to know the correct fluid for when I flush it, if this isn't the correct fluid. Thanks.
/ Ford 1900 coolant #2
I had a 1900 and 2110 and used quality pre-diluted regular anti freeze from WalMart. If I recall, that's the type the owner's manual called for After a while I switched to Deere pre-diluted anti freeze. I always flushed the system first and never had a problem with either.
/ Ford 1900 coolant #3
Who knows what the green stuff is or if it has been treated in any way. Typically, green is a low quality 2 year coolant, or it could even be some of the new Prestone stuff. Since it's summer, just add a little water if you don't need much to top off. Then consider changing over to a better extended life coolant before winter and you'll know what you have and be protected at the same time.
https://www.tractorbynet.com/forums...regular-prestone-post5081276.html#post5081276
Just make sure you do not have a brass/copper radiator that the long life antifreeze will remove the solder joints holding it together. Green is not a low quality coolant by the way.
/ Ford 1900 coolant #4
I never heard of anything like this with long life antifreeze. Can you tell me more?
/ Ford 1900 coolant #5
Keeping Your Cool Over Antifreeze Use - tribunedigital-chicagotribune
A 20 year old article that can be a googling starting point.
Had to replace radiator in 1992 Chevy P30 454 due to past owner using the Orange stuff for 5 years per the radiator shop.
Had Dexcool issues with 1998 and 2002 and converted them back to old school Green since they had copper radiators.
It is almost a NON issue because copper radiators have not been used in new cars for 25+ years.
We have radiators from 1966 forward so I buy the Greeen stuff by the cases for our brass/copper radiator machines.
/ Ford 1900 coolant #6
I have a 1900 and I use Fleetcharge purple coolant for diesel engines exclusively. And the reason is the SCA additive they use to prevent cylinder corrosion and cavitation due to inherent diesel engine firings.
Steve
FAQ - Fleet Charge | PEAKhd.com
/ Ford 1900 coolant #7
Maybe I shouldn't have said low quality. Short term, meaning 2 years, might have been better. Personally, I usually don't consider anything other than an ELC. Yes, I have blinders on. ;-)
The copper/brass comment is a good one. Like you said in another post with copper/brass out of production for 25 years, it's almost a NON issue today, and I never gave it a thought. Traditional green coolant would be the better way to go if you don't have an aluminum radiator. Some of the HOATs are acceptable, but you really need to research them. Sorting through all the available coolants today is far worse than dealing with oils.
All this is new and confusing to me. I put Prestone XL long life anti freeze in my 1960's Ford 600. OK or not OK? Package said good for everything.
/ Ford 1900 coolant
Thanks for the feedback!
/ Ford 1900 coolant #9
It is very confusing so I just run with the metal type of the radiator of the tractor/auto I am refilling.
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61306)
2021 Gehl RT215...
INSPECTION (A61165)
INSPECTION (A61165)
2007 Amkus Rescue System (A59228)
2007 Amkus Rescue...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
