Help me out with free TV.
/ Help me out with free TV.
Excellent advice, as usual for TBN, thanks guys.
My roofline is very high. The painter rented a man lift! So I won't be going up there to put a pole up.
I think I'll try a small indoor antenna first and see what I get. At one of the big box stores I saw a rather large antenna that is made to go in the attic. Is that something that might work?
/ Help me out with free TV. #23
As I said, my antenna is standing on my deck, no where near the top of the house.
And yes, all your current coax will work, just hook the antenna where the cable used to come into the house.
Just can't run both through the same coax at the same time.
Indoor antennas are no where near as good as outdoor.
/ Help me out with free TV. #24
We're about 6 or 8 miles out of Charlottesville, Va. With rabbit ears, we can get ABC, CBS, Fox & NBC plus 4 PBS channels. Also get 2 weather channels and 3 others via the local CBS and NBC transmissions. Occasionally can get the PBS channels from a completely (and farther away) source.
It's weird though. In our main TV room, it has trouble bringing in ABC and sometimes CBS. Have tried various other devices other than the rabbit ears on it with no success. Rabbit ears work as well as anything. We do have DirecTV (have a Comcast cable into the house, but you cannot deal with them any more after being bought out by some big outfit). DirecTV has the local channels and solved the occasional ABC/CBS access problems.
You don't need boxes, etc. just a cable from the Rabbit ears. Just have to turn the TV selection to "antenna" vs. cable.
Ralph
/ Help me out with free TV. #26
The larger parts of analog tv antennas, were meant to receive the parts of the television band that has been abandoned, during the digital conversion.
So, while a large analog antenna will work fine for receiving digital tv, the newer designs, take the digital change into consideration, so they are not nearly as big as they used to be.
That being said, there is plenty of snake oil out there. So, beware.
If you are close enough to the transmitter, a piece of bare wire can receive a signal. So, some people will insist the "gimic" stuff works great. Make sure you can return it, if it fails to deliver for you.
/ Help me out with free TV. #27
K7LN, I disagree on one small point re coax, I have found that if you don't use quad RG6 it can be (but not always) susceptible to interference from electrical sources, also 'F' connect on splitters and diplexers will eliminate a lot of pixelating when electrical devices are switched on and off.
Not always the case but I like the insurance of not having to do it again.
One major problem we used to encounter was electricians doing antenna installs, they generally seem to have no concept of RF and treat it like house wiring, I have seen coax 'strangled' with cable ties and hate to think what the impedance would be, also work on the more signal the better, saw one install with an amp putting out close to 160dbmv, wondered why the TV didn't work:eek:
My own choice of antenna is a log periodic, high gain yet compact, at my place I use a band 3-4-5 which covers the entire digital spectrum with about a 9dbmv gain.
/ Help me out with free TV. #28
And here the wife and I have almost the top package or maybe it is the top package from Directv. And I spend most of my time on Facebook or TBN.
/ Help me out with free TV. #29
You should be able to pick up all the stations from Charlotte and some from Columbia. We live about 6o miles from Atlanta close to I 85 and we pick up all the Atlanta stations and some from Greenville. All we use is the old analog antenna that we put on top of the house more than 30years ago long before digital was available. This antenna will pick up digital stations very well. I have no idea how these new digital antenna will reach. I doubt they would work as well as the commercials promise
/ Help me out with free TV. #31
My feelings also. What's the solution?
I have a channel master ota dvr. Also have a cheaper one called homeworx i got from amazon for $35.
/ Help me out with free TV. #32
Today I got my Cox cable bill. It went up $28. $119 plus taxes and fees for the basic TV channels. This does not include the internet charges. No HBO, Cinemax, Showtime, sports networks, and many other channels I don't get.
I phoned up and cancelled my Cox TV. I am keeping the internet because it is a lot cheaper than the TV and I get all the Amazon Prime shows and my Firestick gets practically anything I want to see.
Of course they raised my internet $10 since I am no longer "bundled". I have very cheap little flat TV antennas that I put on. The first TV I get 38 channels and the other TV I get 30 clear and 4 bad. I think I need to adjust that antenna.
While I was camping I got hooked on Grit TV with all of the old westerns that I watched when I was a kid and have forgotten. Now I can watch Grit for free over the air. The only downside is that I can't go to sleep with the TV on the Firestick channels because I use up a lot of MBs that way and if I use over 1TB a month they charge me extra. The only problem I have is that my wife wants to watch COPS most of the time and hates using the Firestick. I guess I have to give her a little more training.:rolleyes:
/ Help me out with free TV. #33
Ahah! My mom's Suddenstink went up $20 last month to $135 for just TV, no premium channels, no internet. She has an offer from ATT for something cheap, but I haven't read the fine print.
Tells me the cable industry is in cahoots.
/ Help me out with free TV. #34
D A M N Laying here in bed and see you call it SuddenStink. That was a laugh out loud moment. Glad I didn’t wake the ol lady up.
/ Help me out with free TV. #35
Today I got my Cox cable bill. It went up $28. $119 plus taxes and fees for the basic TV channels. :rolleyes:
My basic Diretv, {2 sets}, with no movie channels, is $117. My parents pay $228, for Spectrum, with no internet service. :eek:
Can't blame them for charging that much, we keep for paying it. :confused3:
We are our own worst enemies here.
/ Help me out with free TV. #36
I thought you were cheaper than what we were, AU$88 month for unlimited internet and phone, internet is 24mbs and all calls are included in the price.
Netflix AU$14 month for HD two TV's.
Mobile phones are AU$15 including calls, there is a limit for calls and data but I have never hit it yet.
Our provider is Dodo
/ Help me out with free TV. #37
We're told we can't have something like that because our country is so big and the infrastructure would be very expensive and ....., oh wait a second.
I'm using Silicon Dust tuner running recording engine on ubuntu server, with nvidea shield as the end point, connected to tv. I can do OTA DVR functions and online streaming using android apps on the shield.
/ Help me out with free TV. #38
My camper trailer has a decent antenna and when we go camping we get up to 35 channels at some places and rarely are in an area where we can't pick up anything.
That's kinda sad to me.
/ Help me out with free TV. #39
Forgive my lack of technology, but this sounds like a foreign language to me.
/ Help me out with free TV. #40
He's got a DVR tuner recording over the air TV onto a computer running a Linux operating system.
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
Massey Ferguson 285 Loader Tractor (A66285)
Massey Ferguson...
2018 Nissan NV200 Cargo Van (A61573)
2018 Nissan NV200...
Roll of Barbed Wire (A64119)
Roll of Barbed...
2006 MACK VISION (A65643)
2006 MACK VISION...
