   / Harbor Freight Tools that don't suck #9,501
I bought six of those bit sets. Gave one to my son and I need bits in the shop, basement, garage and pole barn. Too cheap a price to carry a set of bits from place to place. They are not stellar but they work ok.
I have multiple drill drivers as well. I rarely n Ed to look for a driver or bit when doing something.
   / Harbor Freight Tools that don't suck #9,502
I also have a set of the larger drill bits that come in a wooden box and are up to maybe an inch or so and maybe larger. They don't seem to be on the website so maybe discontinued. I use them as a progressive drill after I've already made a smaller hole in the metal. They work fine for that purpose with a slow drill press and cutting oil. I don't want to find out if they would drill a hole on their own and don't think they would.
   / Harbor Freight Tools that don't suck #9,503
Sounds like a Silver & Deming set. HF still has those. [URLhttps://m.harborfreight.com/silver-and-deming-drill-bit-set-8-pc-61802.htmlURL]
   / Harbor Freight Tools that don't suck #9,505
... some added punctuation to make the link work.
I bought those, too. I've only used the one I needed at the time, so no opinion yet to share.
Yes, that's the set. Slow drill press and cutting oil make them acceptable quality for enlarging holes. I can't even imagine what a 1" USA bit would cost.
   / Harbor Freight Tools that don't suck #9,507
For holes over 1/4" I always use a progression of larger bits. I have a set up to 1" X 64ths and have used them enough to conclude they are not made to start from a prick point. Slowest speed on DP and cutting oil always. High speed large drill bits are production items and are very costly. Not sure yet if HF's sets will last on high speed as they advertise. Probably will not know, with my life span that is left.
Ron
   / Harbor Freight Tools that don't suck #9,508
Has anyone used the HF Haulmaster Truck Bed Cargo Unloader? At $40, it's hard to beat the price. I'm just wondering if it's junk compared to some of the other models out there (Northern Tool sells the Boxer Truck Bed Unloader which from the looks of it is just the HF unit under a different name and for $10 more). Then there is a big jump up to $100 or so. Do you lose much in terms of durability by going with the HF or NT unit over one of the more expensive brands?
   / Harbor Freight Tools that don't suck #9,510
Yes, have it. Love it. Works great. Reasonably well built, too. Can dump an entire pickup bed of mulch in a minute or two. Great labor saving device. Takes some muscle to crank when fully loaded, but it works.
Wheel Barrow (A57454)
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
Aluminum Horse Colt (A57454)
Aluminum Horse...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
5500lbs Pallet Jack (A56860)
5500lbs Pallet...
2014 Freightliner 122SD Day Cab Truck, VIN # 3AKJGNDR0EDFL0999 (A57453)
2014 Freightliner...
