paint code for Orange paint
/ paint code for Orange paint #22
It wasn't flat black. :) It was Dark Grey Semi -Gloss and you just happened to get lucky. Ok, maybe skillfully lucky but I'm like Columbo with paint colors and they need to be factory correct. Yes, Ok, you got it right. Good thing we didn't bet. :D
I don't think Kubota even has a flat black.
You are indeed correct and I humbly apologise for my transgression.
/ paint code for Orange paint #23
The irony of all this is that I am red/green and pastel color blind unless the colors are out in the open and separated.
/ paint code for Orange paint #24
Hi guys, I live in a country where everything is hard to get, we can not get the original Kubota paint, been looking for an automotive mix code for years now for hte Kubota Orange 2.
Does anyone have it?
Been using Ral 2008, RAL 2009 but it is not it... when one puts htem on the same tractor...
If anyone has it, please post some numbers, codes, RGB, Ral, whtever can help.
Thank you.
/ paint code for Orange paint #25
Thank you.
If you have access to Amazon, here is what you need to know"
For a quart, from Amazon, you need to use TTB27-QT TTB ($20.41 USD)
For a gallon use TTB27-GL TTB ($46.71 USD)
It is an EXACT match for Kubota #2 paint!
I would recommend using some Valspar hardener also.
/ paint code for Orange paint #26
Thank you, unfortunately not, we can get any of the automotive mixes from all of the main figures in automotive paint industry but I need a color code, RGB, ral, pantone... Kubota is so unfair, they sell their tractor, thir dealer does not import the paint and we are stuck...
John Deere 5090GN (A60462)
John Deere 5090GN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
Case Titan 3530 (A63118)
Case Titan 3530...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
