newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 13,325
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
I'm working on a project to build a "foam gun" for aircrete with 4" PVC and want to seal the fittings TEMPORARILY because I'm not sure what sizes will work best, I expect to be trying to swap stuff around and the fittings run about $4 each. I will be putting air and water in under about 50lbs pressure. The fittings start off pretty tight without any bonding. I'm thinking of using a little bearing grease or smearing on teflon plumbing paste. Any suggestions?
