Left Front Wheel fell out. 4025 4WD with FEL
/ Left Front Wheel fell out. 4025 4WD with FEL #41
Not sure what "upgrade" they mean. None of the schematics I have show any other version. Not even on the 4540 (New model number of the 4025). Checking those every 10 hours would be a pain, as the front final drive housing has to come apart, requiring a new gasket, fluid, etc. Not something I would do, or have done. I would lift the front end with the fel, grab the front wheel, and check for free play periodically.
/ Left Front Wheel fell out. 4025 4WD with FEL #42
You owners with this model should consider yourselves lucky. The 2500 series tractors axel is held on by a snap ring! :shocked:
/ Left Front Wheel fell out. 4025 4WD with FEL #43
That's all that holds axles in many trucks. Should work for a tractor.
/ Left Front Wheel fell out. 4025 4WD with FEL #45
It all depends on bearing size, distance between bearings, axle dia, groove and snap ring size, etc
/ Left Front Wheel fell out. 4025 4WD with FEL #46
I know this is an old one but any updates on this? I had this exact same thing happen.
/ Left Front Wheel fell out. 4025 4WD with FEL #47
As someone mentioned the 2500 series or now I guess the 2600 series tractors use a snap ring to hold the front tires on. As anyone ever had this happen or heard of it happening on one of those tractors.
2016 Bobcat T650 (A60462)
2016 Bobcat T650...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
