HarryVanderpool
Gold Member
What is the load rating for the front axle (including bucket) for the tractor in question?
How much weight was being lifted?
1. Loaders are NOT always matched to a particular tractor. Many times there's several loaders that will fit one model of tractor. There were at least three, that would fit my tractor, I chose the one that I wanted.It's my uneducated belief that all tractors regardless of size category use factory equipped FELs that are capacity matched to the tractor. If that assumption is correct YOUR larger tractor is just as likely to suffer front axle failure when the FEL is used to it's capacity as the OP's much smaller CUT tractor. Am I missing something?
2. I DO agree on your second part... I've seen more than a few farm tractors with busted front ends. I myself shelled out a ring/pinion on a
farm tractor... Abuse the tractor with a loader and you WILL be fixing it! Thing is, a FARM tractor will take more abuse longer...
I had sold my dozer long before and was using my FARM loader tractor to clear some land, dig out some stumps and move them. The tractor took it for quite a while, but one day it had enough abuse and BANG!
I took it apart and with the ring/pinion in my hand, off to my FARM TRACTOR dealer I go. The owner was an older guy that been in business a LONG time and pretty much seen it all. He took a look at what I had in my hand and said "so you been using your tractor for a dozer, have you?". He nailed it, spot on and that was the day I started looking for another dozer!!
BTW, he got me the parts and I did all the labor, including setting up the new R/P, it ended up costing me a bit over one thousand dollars!
I DO NOT use my loader tractor for a dozer, I would NOT load the bucket full of rocks and drive any distance with them and when you see me post picts. like this,
You NEVER see me brag about how far I drove with it, because I don't do it!
SR
Can't bale with an L series? Lol
...Kubota didn't warr. it because THEY said he should have bought an "M" series, the "L's" weren't made for baling hay.
You have a Kubota, so let's use that brand for an example.
Why do you think Kubota makes a "M" series?? I mean they have "L's" with just as much hp as the small "M's"...SR
:thumbsup:Tractors aren’t dozers or excavators or industrial machines. Using them as such is likely going to break them. I think we can a agree that using the right tools for the job is the best.
Let's stop and think about this a second.
A. Pretty heavy load of rock in the bucket
B. In 2wd it starts spinning. Well what does that tell you? Does it say the rear wheels are off the ground or extremely limited in their weight carrying ?
C. Engages 4wd . . So now all the weight and all the drive requirements are on the 2 front wheels.
D. Now this has happened multiple times where the front end transmission goes out?
E. If this were a hydraulic problem the pressure relief would have kicked off. And that didn't appear to happen that it was the hydraulics. So if the front wheels were sliding or moving and you shift it into 4wd, it would set gear teeth against gear teeth. Was the rear differential lock also depressed at the same time?
Normally I'm always in 4wd before I start lifting a heavy load.
If I can't toss a hand full of rocks in a loader and use 4 wheel drive, what h___ good is four wheel drive??? If the loader will list it, with today's relief valves, you can not be overloading things. If dealers , salvage yards are telling you there is a problem with this model, that's all there is to say. Open and shut case. What about the 3 times the front axle failed and no rocks were involved. What about the steering cylinder??? This particular has from end issues.that is open and shut case, admitted to by an agco dealer and 2 different ag salvage yards.You made a very good point. With the rear w spinning its an open and shut case. I have trashed jeep front axles and diffs by loading up the front axle then dropping into low range like a dummy shifting the entire weight I'm winching onto the front axle wheels cannot turn but engine can something has got to give. AxleHub you hit the nail on this one i believe these incidents were caused by operator error
I doubt there痴 a single compact tractor on earth with over 100 hours and a loader that hasn稚 sea sawed over the front end a few times. That shouldn稚 bust the front end.
But if you are in 2wd and your wheels are spinning and you pull the lever to engage 4wd while the rear wheels are till spinning. . . It will then.
Yeah, given that the maximum load is governed by the relief valves it's poor engineering to not build a tractor to withstand that standard case.
I've also never seen mention of it in any user manual aside from stability, unlike how you see for backdragging with a loader.
I doubt there’s a single compact tractor on earth with over 100 hours and a loader that hasn’t sea sawed over the front end a few times. That shouldn’t bust the front end.
I'm not trying to be disrespectful or sarcastic, but I also never seen listed in any of my new car owners manuals that driving into a brick wall may damage your new car. They cannot list everything. Most manuals have several pages of common sense stuff in the front put there for people without any.
