Finally got a Boom Pole
/ Finally got a Boom Pole #1
GrumpyJoe
Felicity, Ohio
Mahindra 1533 HST w/ FEL
Went to Tractor Supply today and looked at the boom poles they had. Which turns out to be only one. Advertised on-line as a HD Countyline for $299. But saw a sticker on the side that said Tarter. Not going to argue with him since the HD Tarter on-line goes for around $365 plus shipping. I used it when I got home with no trouble at all. I do need a better setup as far as chains or straps go. But it's going to be about 95 degrees with a heat index of over 100 tomorrow so I don't see me outside all that much.
/ Finally got a Boom Pole #2
Looks like a good one...I use mine all the time...can see what I'm doing much better than trying to use the loader without a spotter...
A hydraulic top link makes a boom pole like a mini crane...but the best thing I did to mine was add a receiver ball so I can haul my trailer without removing the BP...
...I can drop the trailer and use the boom to load it then just pick it back up and I'm off...
/ Finally got a Boom Pole #3
A "safety Police" observation.
Your pulling forces, should you do more than just lifting, are going to be high up on the tractor which is the receipt for a flip over backwards.
You have a roll bar so use it and the seat belt. Consider adding wheelie bars like drag cars use.
You will, find endless uses for it.
Dave M7040
/ Finally got a Boom Pole #4
Tarter & King Kutter make some or most of the TSC impliments. They rebrand them as CountyLine, but lots of manuals & stuff have the OEM designations & stuff in them. Not sure if it's a regional thing or time thing when their various contracts have come & gone.
Not saying it's a bad thing at all, just a thing.
/ Finally got a Boom Pole #5
Hey, that's cool. Hadn't seen one of those before. Thanks for posting.
/ Finally got a Boom Pole #6
Wish I had one designed like the OP. Mine won't fit the QH that was bought later. Thus, I try to use the FEL after all.
/ Finally got a Boom Pole #9
Also if I'm using the loader with chains for picking or dragging something uphill backwards that weighs a lot, the back tires might come off the ground and that is not good.
/ Finally got a Boom Pole #11
I have the TSC HD Tarter as well, very handy for those extended reach tasks.
/ Finally got a Boom Pole #12
I found that I generally do not need a helper when using the FEL, since I can easily rig the chain/straps to control the sway of the object. With the Boom Pole the object is more difficult to control once it's off the ground....i.e. working by oneself. 429.JPG437.JPG
Cheers,
Mike
/ Finally got a Boom Pole #13
I use my boom pole purchased at TSC all the time to 都kid logs all the time
Keep the log low enough where you are doing more pulling than lifting you will be ok. Just use common sense
Have fun with it
/ Finally got a Boom Pole #14
Probably a dumb question, but how much lift or range do you get with these? 2 feet?
Thanks
/ Finally got a Boom Pole #15
More than that. Maybe double that. The range is adjustable on some using the different holes in the top link spot on the tractor if so equipped.
We had one for decades on our 2wd 40hp non loader tractor. My Dad had the guys in his company shop build one for free. A loader would have cost MONEY! We used it a lot. One guy could carry it and put it on in a few minutes.
Our tractor had no front ballast and non filled front tires, yet the modest lifting force never raised the front wheels.
/ Finally got a Boom Pole #16
I have a boom pole but the first time I tried to use it to pull a pole out of the ground it lifted the front wheels of my 8N clear off the ground. Turns out the pole I was trying to pull out was anchored in concrete. D’oh!
/ Finally got a Boom Pole #17
I have a boom pole but the first time I tried to use it to pull a pole out of the ground it lifted the front wheels of my 8N clear off the ground. Turns out the pole I was trying to pull out was anchored in concrete. D弛h!
That's funny. One second cursing at why the dang thing is so weak and can't pull a little pole....and then, oh....never mind...good tractor. :laughing:
/ Finally got a Boom Pole #19
I learned my Ford tractor's 3pt lift limit trying to move a concrete bird bath :) Just shuddered and wanted something else to move. I've skidded some big logs with it though.
/ Finally got a Boom Pole #20
Here’s mine.
Four (4) John Deere 8R Front Fenders (A65640)
Four (4) John...
1996 Ford F-350 Pickup Truck (A64194)
1996 Ford F-350...
2007 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2007 MACK GRANITE...
Concrete Mixer (A66408)
Concrete Mixer...
John Deere 2640 Tractor (A62613)
John Deere 2640...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
