Steering chatter/ studder ck2610
/ Steering chatter/ studder ck2610 #1
mmecsics
FL
Kioti ck2510 hst
Have about 30 hours on my 2610 now. I have noticed that once it'sエ warmed up, it seems to have a steering chatter/ studder while making turns. Ive checked the hydraulic fluid level, checked to make sure the steering wheel nut is tight, and it will do it at any rpm. Anyone have any ideas before I call the dealer. Thanks.
/ Steering chatter/ studder ck2610 #2
I have right at 50hrs ok my 2610. I have the same issue. It may be my imagination but it seems my hydraulics get a little weak as well. Hoping the 50hr service helps.
I don稚 think it痴 your imagination, because I feel the same. I知 not very impressed with the kl2610 loader either. I asked my dealer about a upgrade when i purchased it, and was told it would void the warranty. Now I see the tractors are coming with a kl4030 loader. Which should be a huge improvement
/ Steering chatter/ studder ck2610 #4
I was told the same thing. I'm happy with the tractor otherwise. The 4030 loader is $4300 without trade in. Dealer is unsure of what he can offer on the kl2610 on trade.
/ Steering chatter/ studder ck2610 #5
Im not experiencing this. Im always in 4 wheel drive though. I'm at about 75 hours. Have done my 50 hour service already. What are you two running in when this occurs?
My dealer and I had a discussion about this loader change in fact this weekend. He's been a 5 paw dealer for years, even traveling to Korea a couple times. His thoughts on this are two fold. They decided to simplify the line so as not to carry a single FEL for a Single tractor after they determined this other could fit and fit several tractor models. But there is no evidence that this 2610 tractor can perform any better with it than before or fully take advantage of anything it offers. The numbers don't mean much more than the tractor can provide to it. He believes its a cost savings move and assembly line simplification more than anything. It simplifies the parts lines and inventory from this point forward. If it provides a little benefit its unmeasurable and yet thats just fine and dandy and if it sells a unit and people believe it does then good. He knows of no side by side comparison that shows its an advantage and seriously doubts its measurable in the 2610. fact is for the years it was made the loader matched that tractor and met its needs. They simply do not want to continue to make an orphan unit the 2610 for the 2610 when they can make one unit to fill all the demands. Who knows. But specifications are specifications. They are "paper". Real world is totally different.
Heres a 2610 ripping out some privit hedge by the roots today. You gotta work it around though. Several angles before the roots give way and pull out. But it seems to me its then more the tractor doing most that work and or bogging when it hits roots than it is the loaders capability... I am guessing. But it does it.. it does the work.
Hard to explain the steering chatter, happens at random times. As for the loader, Im pretty sure the 2610 has the same hydraulic pump as the bigger tractors, so it will run the loader the same as the bigger ones, I知 guessing 4030 loader either has better angles for more lifting power, or bigger cylinders for more power. I just feel that my loader is lacking. I honestly feel that my ck2510 had more lifting power. Probably because it had a smaller bucket.
/ Steering chatter/ studder ck2610 #7
Feelings are one thing but I doubt your going to achieve more with the different loader. The limiting factor being the HP Weight ratio of the tractors. And you'll note that you can stall the tractor down while doing things that involve the pump. Like a grapple. So the HP does affect the ability to drive that pump. Id love to have both side by side and thats the only way you can probably try and determine it. Same tractor same conditions both loaders.
i agree, im more worried about the weird chatter in the steering wheel. Im hoping a quality fluid will help the chatter, 50 hour service is coming up, and my dealer told me he uses the generic fluid from sams at his shop.
/ Steering chatter/ studder ck2610 #9
Did you say you were in 2 wheel drive or 4?
It will do it in 2 or 4 wheel drive.
/ Steering chatter/ studder ck2610 #11
The chatter occurs when the tractor is half warmed up. Does it also happen when the fluid is fully warmed up? When this chatter happens.. if you turn the steering to full lock a couple of times, does the chatter go away? My thinking is that there is cold fluid in the steering system and the difference in viscosity between the warm fluid and colder fluid is causing this chatter. Just a theory.
As far as the optional loader for the 2610 goes. Both loaders require about 2560 psi relief pressure. Both tractors provide that pressure at approx. the same flow rate. I cannot see how you would not be able to use the loader to it’s full potential if properly ballast at the 3pt. The hydraulic system will not stall the tractor. There is a relief valve. The Hst could definitely stall the tractor.
/ Steering chatter/ studder ck2610 #12
I did my 50hr service yesterday. We'll see if that helps with the steering chatter. I changed hydraulic fluid as well.
Yes please keep us updated. What fluid did you use?
/ Steering chatter/ studder ck2610 #15
Ended up using TSC Traveller Premium UTF. I only drove it from my garage to the shelter but it seemed quieter to me. I also noted that I didn't seem to get the 5.8 gallons of fluid that it calls for. I didn't measure it but it didn't fill the 5 gallon bucket. I had the loader arms and 3pt lowered to make sure the cylinders were empty as could be. I guess the oil cooler and hydro had the rest. I did check the level before draining and it was at the upper limit. I put the entire 5 gallons in and it's slightly above the upper limit now.
/ Steering chatter/ studder ck2610 #16
Check if the hydraulicfilter is tighty screwed in ?
A loose filter can do that !
Mine definitely wasn't loose. A strap wrench worked well on both the hydraulic and engine filters. The HST filter was a different story. I ended up using a C clamp that was slightly smaller than the filter. Tightened it until it was gripping 3 sides of the filter. Used a pipe wrench on that and it finally broke loose. Don't think I've ever seen a filter that tight.
/ Steering chatter/ studder ck2610 #17
The steering chatter is just a function of the design of the steering system has little to do with what Hyd fluid your using. The way the front end is designed is that the 2 steering cylinders (single acting) push against each other through both axles and the drag link so the system builds up enough force like a spring and it releases quickly. It will normally do it more with a lower hr tractor because everything is tighter (Seals cylinders, joints knuckle) and cause more spring action once the system wears more everything loosens and less spring action. Greasing the joints sometimes helps but mostly its just the nature of the beast.
Well, the chatter is still there. Can Anyone else with a ck2610 turn the steering wheel with the tractor off and here a clunk? I壇 appreciate anyone trying
/ Steering chatter/ studder ck2610 #19
I have a 2610 with about 140 hrs on it. I can't say I've ever noticed any steering chatter. I always keep my RPM's around 2000. Maybe see if your running your rpm's too low??? Did the 50 hr service and changed both filters. used chevron THF 1000. Wish I could help more? Have you called you dealer?
Does it at any rpm. Been doing it since new, about to do my 50 hour service. Haven稚 asked the dealer yet, will though soon. Just noticed the other day that it clunks even when machine isn稚 running.
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
