Anyone build or make a trailer dolly?
   / Anyone build or make a trailer dolly? #1
Mousehunter
Member
Austin, Texas
2015 Kubota
Just curious. Given my barns and road layout, I often find it easier to disconnect trailers from my truck and push them in with a SxS (front mounted ball). I also have a manual dolly I occasionally use, but a power dolly would be much nicer. Considering a BCS 853, and trying to sell myself on it. I have other equipment, but sometimes the right tool is priceless.
   / Anyone build or make a trailer dolly? #2
Here's one you can buy . Good for 40,000 lbs. I think it's neat so usually post when someone asks about a trailer mover. Scroll down to the last video about the the "Trailer Tug"
Videos - Media
Al
   / Anyone build or make a trailer dolly? #3
You already have a trailer mover. I don't know what size it is but it's called 2015 Kubota in your signature. I made an attachment for my tractor and I use it all the time. I can move bumper pulls, 5th wheels and goose necks. I wouldn't want to be without it. The attachments are also manufactured commercially if you are unable to make one.
Sorry if my searching was weak, I did not see much relating to trailer dolleys and 2 wheeled tractors. I understand people use them to move goosenecks and fifth wheels with a 4 wheel tractor, and I have seen stand alone self powered ones-just have not seen a Grillo/BCS type implement. I have a pole barn with internal supports. While it is easy to park in the middle, about the only way stuff gets parked in the sides is if I can lift them there with a skid loader or push them by hand-no real room to use the hitch and a vehicle.
Fwiw the 2015 Kubota is a skid loader.
   / Anyone build or make a trailer dolly? #7
would something like this work?
   / Anyone build or make a trailer dolly? #8
I made one for my BCS850, dolly attaches to the pin coupler above the PTO. Mine is very simple, a straight bar(channel like road sign post)about 4'long, axle about 25" with foam filled wheel barrow tires and a piece of 2 1/2" square tubing vertical with the ball on top. The ball is mounted on 2" tubing, removable so I can change it out with a seat. It works, works better pulling than pushing, in the yard I use it for moving a log splitter and light trailer. If I were to make it again, I would use the PTO coupler with a short "tongue" and a castor type wheels, power barrow style but shorter. Should work good for tight flat places. I just don't have much flat.IMG_1092.JPGTHis picture shows the dolly with the seat in place pulling a wagon. Seat removes, insert ball.
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
(4) 10' High Pole Swinging Gates (A50515)
(4) 10' High Pole...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
