Backhoe stabalizers won't hold position
/ Backhoe stabalizers won't hold position #1
dwalk19
Gold Member
Addison, ny
2018 LS XG3140H TLB
I just got a used backhoe and have only used it couple 1 time, but i noticed it when parked and on tractor that backhoe stabalizer legs would slowly drop, then when I removed it from tractor I'm pretty sure they lost pressure because backhoe is now setting on frame and not legs,
I could understand I guess if cylinders are leaking by but seems odd they both do it, possibly the valve, what's wired is if it's the valve, where can the fluid leak back to if it's not hooked up to tractor and can't go back to the tank 20180713_205337.jpeg
/ Backhoe stabalizers won't hold position #2
It’s a valve or other leak. Cylinders won’t drift like that even if they had no internal seal- fluid volume needs to change as the shaft moves.
I’d take some photos of the valve/valves and post in the hydraulics section. Keep us posted though!
/ Backhoe stabalizers won't hold position #3
I could understand I guess if cylinders are leaking by but seems odd they both do it, possibly the valve, what's wired is if it's the valve, where can the fluid leak back to if it's not hooked up to tractor and can't go back to the tankView attachment 562525
The simple fix, is to chain your backhoe stabilizer arms together, when there is no active hydraulic pressure available.
My (old Ford) hoe has chain slots in the end of the stabilizer arms so I can keep the arms hooked together (light duty chain) when the hoe is not in use.
Though my hoe is a "quick disconnect" type, I have only disconnected it once...to paint it.
I leave the hoe alone, and use a different tractor for 3pt. hitch tasks.
/ Backhoe stabalizers won't hold position #4
Normal. I just tie mine together with a small rachet strap. That's why you have pins for boom and swing to use when you park it. I also tie the bucket up with a rachet strap.
/ Backhoe stabalizers won't hold position #5
Do they leak down when they are down and you are digging? If so, they are internally bypassing the packings (internal leak) and need rebuilt.
hugs, Brandi
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
2012 CM TRAILER (A60736)
2012 CM TRAILER...
2017 MACK CXU (PINNACLE) (A60736)
2017 MACK CXU...
Case 586E Fork Lift (A60352)
Case 586E Fork...
